Results 21 to 30 of 51
09-22-2021, 04:51 PM #21
I pull from the pylon at the rear, or my two hook points on either side of the stern when pulling both our big 3 seaters at the same time. I don't use a tow ball, and keep my front ballast full and empty rears. I generally keep my center Plate at 50 or so just to give them some wake to bounce over when I sling the piss out of them. Every now and then a rope will get hung in some of the wake, but only for a moment.
05-24-2022, 09:34 AM #22Senior Member
- Mar 2022
- Winston Salem NC
- 157
Hate to hijack and revive an old thread...but...
I've got the bag upgrade and still have the stock storage bins. Am I missing something? The dealer added 1.5min to the timers and they look "full" when I pop the seat up to look at them. Just wondering now if maybe they aren't filling all the way up since I can still fit the bins?2022 Makai 400
15.5x16.5 prop (18 back up)
Chilltech
Premium Wetsounds Package
WakeMakers (custom) bag upgrade
05-24-2022, 09:47 AM #232019 Makai
Raptor 450 w/ 1.76 Trans
05-24-2022, 09:48 AM #24Member
- Aug 2020
- Charlotte, NC
- 74
I have a post on the FB group where I talk about venting the rear bags from the top to get all the air out as you fill. That way you dont have a bunch of air in your bags. You can also manually burp your bags by cracking the top vent cap while you fill as well.
Lake Wylie, NC/SC
2021 Moomba Mojo
05-24-2022, 09:55 AM #25
Good point! To me this is a must. I vented off the top of both of WM bags T'd them in to the factory overflow and I put check valves just before the fitting that goes out the side to help with draining. TBH I am going to find a way to also vent the bags under the bench seat and tie it into the same line. It is so nice to not have to burp the bags.
2019 Makai
05-24-2022, 10:15 AM #26Senior Member
- Mar 2022
- Winston Salem NC
- 157
I'll measure the depth soon but 6" seems like what I have. It's odd because I asked the salesman about it and he said they'd fit and even had a story about another customer who put lead in the bins.
I'll try the venting next time out after I get the bins out. Is the vent cap obviously just on top?2022 Makai 400
Chilltech
05-24-2022, 10:23 AM #272022 Mojo - 400 - flow 3 - OJ 930 15.5x15 prop - 1k lead - 2.5-3k elevation
previous: 2007 centurion elite V air warrior
05-24-2022, 10:27 AM #28Senior Member
- Mar 2022
- Winston Salem NC
- 157
2022 Makai 400
Chilltech
05-24-2022, 11:00 AM #29
The 2021 Makai storage bins are 11" deep. Plus or minus thickness of the plastic.
05-24-2022, 11:24 AM #30
interesting , i will measure mine tonight, they dont seem as deep, but maybe they are.
side note, do yours catch the vinyl/cover? i had to round off the sharp edge on mine because it was snagging the vinyl seam every time you opened it.
also, i thought the WM bag upgrades didnt add much to the top and more added to the front/under seat. the WM bags are listed as only 1345x2, stock 2022 is 4k total, and i dont see the front bag being more than 1310LBLast edited by vdubnick; 05-24-2022 at 11:26 AM.
