Results 21 to 30 of 60
Thread: Plumb in extra rear bag?
06-22-2013, 09:35 PM #21
I don't know what to tell you, really. It's a disease and the upgrades can't be stopped in my world. To be clear, my 08 lsv is setup as follows: 400 in the locker. 650 in the bow, 1100 in each locker (braced), dedicated pumps for each locker and the front/ibs are on their own pump but connected together. I have retained the factory switches and have everything out of sight and plumbed in. All I have to do is hit the switches and let it happen. I did have the same setup with the factory single pump and valves and that worked fine with the exception of fill time. Also, I have multiple props, depending on where I am boating (I range from 4000 - 7000' in altitude on my lakes). Unfortunately, one change will likely spark another and that just seems to continue....
It's an expensive sport/ lifestyle, I have found.'08 Mobius LSV- SOLD!
2017 Mojo Pro
06-22-2013, 09:58 PM #22
Oh I know the feeling, this isn't my first rodeo. I had at least $800, maybe more, into my fat sac setup in my Launch. Unfortunately, the buyer wanted to keep all of them with the boat! Which was understandable.
So I'm wondering why did you go IBS? I was thinking I'd just go to that longer 1180lb center sac, if I actually stepped up to 1100s in the back. Why plumb in the extra IBS if you can get a center sack that's 780lbs heavier than our stock ones? I just assume it goes way up into the bow. It's 88x19x19. I think our stock ones are just shorter, but same width and height.Boats previously owned - 2000 Supra Launch, 2003 Outback, 2006 Mobius LSV
06-22-2013, 10:05 PM #23
06-22-2013, 10:10 PM #24
06-22-2013, 10:14 PM #25
Also could anybody tell me what the difference is in hose fittings? Like why on wakemakers if I upgrade to 750lb or 1000lb sacs do I need a new quick connect extension adapter with it? I would think that I could just pull the quick connect plugs out of my bags and put them in the new bags, as I assume all Fly High sacs have the same size holes. Am I wrong in assuming that?
06-22-2013, 10:21 PM #26
06-22-2013, 10:23 PM #27
2017 Mojo Pro
06-22-2013, 10:54 PM #28
Sorry, I just realized I misread your question. The holes are the same and you can swap the fittings. Most would upgrade to 1" fittings when going to a larger bag, but that requires upgrading hoses as well. Doesn't sound like you are going to that stage right now.
2017 Mojo Pro
06-22-2013, 11:02 PM #29
OK great, yeah that was my question. There's a couple members on the forum I'm talking to about getting their 600lb bags from, and I had just assumed I could swap out my fittings on to that bag.
06-22-2013, 11:05 PM #30
I see no reason why that won't work.
2017 Mojo Pro
