Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 106
    Oct 2018
    Hockley, Tx
    So I took the total weight of truck and trailer in the second ticket (15480)and subtracted just the weight from the first ticket (8560) and came up with a trailer weight of 6920. Then I subtracted the weight on the trailer axles (6380) from the total weight of the trailer and got 540 lb tongue weight.
    You can also add the weight of both truck axles from the 2nd ticket (9100) and subtract the weight of the truck from the first ticket (8560) and it comes out to 540 again.
    Looks like a trailer weight of 6920 with a tongue weight of 540.
    So now that I am at my desk I sat down and looked at it and didn't have to flip back and forth between pics and apps lol
    The trailer weight is 6,900# (15460-8560)
    The tongue weight is 620#...... I did it both the way you calculated it ((15460-8560)-6280) and the way I did (9180-8560) and they both came out the same lol
    Quote Originally Posted by Shoebox View Post
    If that's the actual tongue weight, it could make handling squirrelly. Should be at least 10% of the trailer weight.
    Ya it actually handles great!! It is right at 9% which I would prefer 12% but I am going to put the lead in it this week and can manipulate it a little bit where needed.
    2019 Makai
    Raptor 450 w/ 1.76 Trans
    Am I looking at the ticket wrong? Looks like 6380 and not 6280. Either way it’s close enough and if it’s not swaying I’d say you’re good to go.
    Oct 2018
    Hockley, Tx
    LOL your right. Busy day LOL all my numbers were screwed up SMH LOL
    2019 Makai
  4. #24
    May 2019
    WA
    Well tag wasn't there so called the dealer. Have a class 4 hitch. 14,000lb gross trailer weight. 1400lb tongue weight
    2019 - Makai took delivery
    2018 Yamaha AR195 SOLD
  5. #25
    May 2018
    Default Makai extra weight setup
    Quote Originally Posted by Arcadyus View Post
    No way does a 2017 ram 1500 come with a 14000/1400# hitch. I call BS.
    A quick search of Ram factory hitch shows me this.
    You have to go by the tongue weight rating as boat trailers are not WDH compatible.
    5000# and 500# tongue.
    Don’t feel bad,Ford did the same shit until model year 2019.
    Wakeboats push the limits of a half ton.
    Not trying to be an ass, but there are way to many trucks pulling wakeboats with improper hitch equipment. Failure it catastrophic and the responsibility of the owner. I also believe the insurance companies will deny claim based on improper equipment, again fault of owner.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
  6. #26
    May 2019
    WA
    It's not a normal 1500. It's a longhorn Laramie and he confirmed it by my vin number.
  7. #27
    May 2019
    WA
    That 5000lb and 500lb says it's the bumper rating only. So are you thinking I need a different hitch. We pull our 31 ft travel trailer with this truck all last year.
  8. #28
    May 2018
    Good luck to you.
    2021 Supra SA 400
    Michigan
  9. #29
    May 2019
    WA
    Our trailer has a 800lb tongue weight
  10. #30
    May 2019
    WA
    what would your suggested fix be?
