Results 11 to 16 of 16
Thread: Gravity III upgrade
12-04-2019, 10:09 AM #11
Gravity III upgrade
If your adding large bags in the lockers I highly suggest you get one 800 pump for each bag. Once you get over drilling one hole in your boat the next ones easy.
I’ll get pics underneath a little later.
First pic is pump just in front of the v-drive starboard side.
Second pic is the pump on the port side of the v-drive.
12-05-2019, 01:01 AM #12
As long as you’re doing it, why not use an 1100 or 1200 instead of an 800??? Also, why not increase the hose from 3/4” to 1”??? My original rear drain pumps both burnt out in the last couple years and I put the Rule 1100’s in from Wakemakers. I had to increase the size fuse but otherwise it works really well, even with 3/4” drain hose. I’m hoping to increase my drain hose this year to 1” to decrease drain time even further.
twkoehn
1100s in rear lockers
750 lb IBS
Acme 1847
12-05-2019, 09:16 AM #13
12-05-2019, 09:08 PM #14
12-11-2019, 04:41 PM #15
I'd like to know what your fill and drain times are. Keeping the slow pumps and keeping the 3/4 line would be painful with 1100 rears and 1180 gravity bag... I'm well under 10 minutes with the T1200s and the larger hose.
www.TraysonsToybox.com
12-13-2019, 10:37 AM #16
Under 10 minutes is really good. The 800s do a pretty good job. 14 minutes to fill 2 1100s and a 1380. I have the fat sacs that have a 3/4 inlet. I figured this would choke off the 1200 pumps and you wouldn’t get the full capability out of the pump. For the money I spent I am satisfied.
