Results 91 to 100 of 156
Thread: April 2018 Picture Thread
04-19-2018, 08:35 PM #91
The weather and my schedule finally cooperated. Water was set to a bit chilly at 48 degrees... Drysuits are a good thing.
www.TraysonsToybox.com
04-19-2018, 08:38 PM #92
So I donned the drysuit and even looked silly with my neoprene cap. The things I'll do to get my surf fix.
All in all it ended up being a nice day on the water.
04-20-2018, 09:13 AM #93
04-20-2018, 11:35 AM #94
04-20-2018, 12:16 PM #95
Made a cheap fluid extractor using a bucket, couple fittings, hose and my shop vac. Works like a champ.
Last year there was a 12" sub in a smaller sealed box at the helm down at my feet. Wanted to pick up some space under there and was planning on notching the floor hump to slide it back. Then I ran across this ported box and tested it out. Sounds way better so Im trying to fit it in there now. The first picture is as far back as it would go with the hump. There is plenty of room now. Just need to figure out where it sounds the best, finalize placement, add feet to the box, finish the fiberglass and carpet on the hump removal. Then build false wall and footrest.
IMG_1071.jpgIMG_1072.jpgIMG_1074.jpgIMG_1478.jpg2006 XLV
04-20-2018, 12:19 PM #96
Removed both floor panels while I was doing other things. I planned to replace the carpet this year, or swap over to foam flooring. Projects and time got away from me. So I quickly rinsed down the carpet with the hose and dyed it with RIT dye. I had no idea how it would turn out, but it was worth a shot and quick to do. Figured any improvement would be better than it was.
Here it is after rinsing several times until the water ran clear. Turned out way better than I thought it would. Wished I would have actually tried to clean the carpet before doing it!
IMG_1386.jpgLast edited by bsharer; 04-20-2018 at 12:23 PM.
2006 XLV
04-20-2018, 12:25 PM #972008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
04-20-2018, 12:28 PM #98
I have some 3 mil booties for surfing. They're very comfy and my feet aren't cold at all. But you don't feel the board as well. For wakeboarding, I have some fleece/neoprene socks that I wear in my closed toe boots. Does pretty good. I was fine in 36 degree water in January that way.
04-20-2018, 01:37 PM #992007 XLV Gravity Games
1,100 in each rear locker
1,180 in front
Fresh Air Exhaust
SuckG8
Bunch of other crap
04-20-2018, 01:45 PM #1002008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
