Results 41 to 49 of 49
Thread: Water over the bow?
01-20-2014, 05:45 PM #41
Water over the bow?
Kind if the same as the Florida boys, you are likely to see one march to may if the river is not real crowded, then they kind of disappear until mid to late sept and then you see them all the way up until we stop riding at the end of November. I see more than one every 6 months, like in the fall it's usually like 2 or 3 in one day.
If there is a lot of traffic out it tends to scare them away
Sent from my iPhoneDavid
01-20-2014, 09:21 PM #42
01-21-2014, 12:48 PM #43
Water over the bow?
01-21-2014, 03:21 PM #44
08-07-2014, 12:38 PM #45Junior Member
- Jun 2014
- 3
When surfer drops turn steering wheel to start turn into surf side. Then go to neutral. The wave turns the boat to finish the turn as you get hit by 2-3 waves. Boat is now through the waves, back in gear and pick up your rider. I found that if the boat is in gear with any amount of forward power, the boat noses into the wave and water comes over the bow. Just start the turn, go neutral & roll through the waves. Pick up takes slightly longer, but worth it.
'08 Mobius LSV
Prop - Upgraded to ACME 1433 - 14" x 14.25"
Ballast - 750 lbs in lockers, 400 lbs in center, 5-600 lbs in bow & 2-300 on the rear floor
325 Indomar
Elevation 5000 - Lake Cascade
08-08-2014, 04:52 PM #46Senior Member
- Aug 2011
- 2,522
Re: Water over the bow?
I wasn't paying attention the other day and hit one of my rollers. Filled the entire bow, water was above the speakers..
2006 Moomba Mobius LSV - Sold
08-10-2014, 04:35 PM #47
08-10-2014, 04:55 PM #48Senior Member
- Aug 2011
- 2,522
Yep, just kept surfing..
08-10-2014, 04:59 PM #49
Water over the bow?
I have a 98 outback and am in a rough lake. Rollers over the bow happen. Nothing for a 60' yacht to go ploughing by you while you are picking up a rider.
