    Oct 2019
    Birmingham, AL
    Default Wake Plate Noise
    I have a new 2019 Moomba Craz. When the boat is in the water in idle, it makes a loud noise. It does go away after the throttle moves forward. My dealer tells me that it is the exhaust hitting the wake plate. I had a 2016 Moomba Craz, and it made the same noise. Has anyone experienced this issue, and is there a fix?
    Aug 2017
    I've never noticed that in our 17 craz
    Yep mine does that as well. You can buy plastic washers and add them to reduce the play. It does help.
    Nov 2016
    Knoxville, TN
    Quote Originally Posted by Surf Wagon View Post
    I think it's actually the exhaust hitting the swim platform and rattling. I've seen people run bigger pins or bolts to tighten it up to take the slack out and the noise has gone away
    2011 Sea-Doo Wake 155
    Apr 2013
    Knoxville TN
    Composite shims work well if you have areas to use them. I used them on my last boat. Lowes or HomeDep.
    2018 Supra SL400
    Oct 2016
    Wisconsin
    I have the same thing (i think) on my 2019 mondo. Couldn't figure it out until now but makes sense. Sounded like ballast was pumping out like a grumble coming from the back of the boat at idle. As soon as i hit the throttle it goes away.
    2019 Mondo
