Results 1 to 6 of 6
    Default Ballast System Leaking
    Hi Everyone,
    I have a 2006 Moomba Outback V, the ballast system fills up and empties perfect but when have it off water continually comes through the lines, if i lift the line up high enough the water will stop. Does anyone know what causes this problem? Are the pumps bad or is it an o ring?
    Thanks
    Cameron
    Commerce Lake, MI
    It’s self siphoning. Add some anti siphon elbows to your overflow lines and it should stop. You can get them from Wakemakers.
    2017 Moomba Craz
    Henderson, NV
    first off assuming you still have the old single pump and sprinkler valve setup? on top of the vdrive there should be a section of hard plastic sprinkler pipes and 3 valves with ballast hose going to each rear and the center locker bag.
    if so is it filling on all 3 bags or just 1.
    first place I would check would be the valves. they could be sticking partially open/closed.
    Commerce Lake, MI
    Good call!
    2017 Moomba Craz
    Awesome thanks guys. I’m heckling the valves first thing tomorrow!! I’ll let you know what happens
    So i have the old sprinkler system with the black on off valves and I replaced all 3 valves and 2 of the O rings, all set now!! thanks for your help. Each valve was only $33.00
