Results 11 to 20 of 22
    They should last 350-500+ hours depending on alignment and cool water housing cooling. If you can align your shaft you can do the conversion. It sure is nice to have a dry and clean bilge imo.
    I'm around 430 so that makes sense!
    Sandm, I'm actually running back up to the dealers today and I'll double check what he told me.
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
    Jan 2010
    North Texas
    Sandm, I'm actually running back up to the dealers today.
    Smh smh smh
    Sent from Galaxy S2 using Tapatalk.
    2006 Supra 20 - Sold
    2015 Supra SE450 - Sold
    Mar 2008
    If you're looking for some dripless underwear, KG's mom has an extra pair or two!
    PWI as usual...
    pretty sure my shaft seal is not leaking and my bilge is NEVER dry do to people climbing in and out of the boat dropping with water all the time.
    i was never able to align my shaft due to the engine just wouldnt move. ill pay the dealer to try this winter
    Persuasion my friend is best accomplished with a crow bar and hammer taping
    99 Outback LS. Sold
    Dealer here said the system was $150 and then 1.5 to 2 hours of labor.
    Sent from my Xoom using Tapatalk
    2016 Moomba Mojo
    Mar 2003
    Springfield Missouri
    I went to a graphite cord about seven years ago and haven't done a thing with it since and no dripping. Teflon is more prevalent now.
    SOLD
    Henderson, NV
    so $3-400 depending on shop labor rates.
    I'm all about the dyi, but aligning the engine is something that I'd rather pay for as I would assume the repricussions of it being wrong are quite expensive
    i used persuasion in the form of a 4 foot pry bar and a 3 lb sledge and got nothing
    with the pins loose prying on the motor mount as you tap the trunnion it did not move? something does not sound right
    99 Outback LS. Sold
