Results 11 to 20 of 20
Thread: Surfing with stock ballast???
07-09-2017, 02:38 PM #11
If you are going #1100s, you may want to reinforce your vdrive divider panels. Wakemakers sells them or if you are a diy guy, go to your local hardware store and make them yourself. This will keep your panels from collapsing in on your engine. I would actually recommend trying to find some ballast bags and a pump from a friend maybe and playing with those in the boat. I have a Mojo, so my setup is going to be different from yours. I have seen people on here go with #900 in the mondo rears. On your surfboard, you need to make sure your toes are as close to the edge of the board towards the wave as possible, and try to keep the board pointed at the boat, not away from it. Also, rise with all your fins on the board starting out, this will give it more control and hold the wave better.
2011 Sea-Doo Wake 155
07-09-2017, 05:19 PM #12Member
- Apr 2017
- 58
I have the same as you stock 500 center and stock 500 bow. I have no plans to upgrade them.
With the 1100s in the back my boat doesn't dig in or list to bad and I'm ok with the stock prop. My boat is a 17 and I've put 107 hours on her and I'm pretty happy with only the 1100s and everything else stock. I'm very new to surfing but this set up does awesome for my family
07-09-2017, 08:06 PM #13
07-09-2017, 10:49 PM #14
Save yourself some time and trouble, order new fittings and sell your old bags complete, the cement from the factory is a mother f to get out, many people have been successful, but many, including myself, have ruined bags trying to save a few bucks
07-10-2017, 09:44 AM #15
07-10-2017, 03:09 PM #16
I got it figured out! The quick connects came off no problem so I just ordered the quick connect fitting that inserts into the 1100 lb bags! 2 for each bag (one for fill/drain and one for vent). Looks like they were 1", hope I am correct on that.
07-11-2017, 12:07 PM #17
You are correct. All the newer Moombas use the 1" flow rite fittings.
05-14-2018, 01:16 PM #18Senior Member
- Mar 2018
- ALABAMA
- 202
If I had it to do over, I too would just sell the stock bags. I tore one up, the entire flange/fitting came out due to the weld on the inside coming unglued from the heat and me prying on it. I was able to get the fittings out of the 2nd bag but evidently between the heat and prying to get the drain/fill valve out, the threaded opening warped. I installed the check valve fitting for the Tsunami pump but it has a constant leak and even though the fitting is bottomed out, it just spins and will not tighten down.
In hindsight, I'd sell the bags, give someone a deal, take the money and reinvest in lead bags.2017 Moomba Helix
Flow 2.0
AutoWake
Surf Edition
WM Rears 1200s
Fresh Air Exhaust
Fat Sac 400s (Midship compartments)
LeadWake bags
05-25-2018, 12:18 PM #19Member
- Jun 2016
- Alberta
- 41
I'll chime in. I have a '16 Mondo surf edition, here in Alberta. I fill the left rear bag 100%, the right 75%, the front 50%, wakeplate all the way up, surf gate engaged (I think it's set around 55). My kids, 100 and 150 lbs, surf like champs on a 4'8" shim board. I'm 200 lbs, took me a bit to get the hang of it and drop the rope but I got it, just takes awhile to get the feel (helps if all passengers sit on the left for me). I've got a 230 lb brother so I ordered a 5'9" board for him and any other beginner.
If I were to do any upgrading I'd replace the rear bags with the 1100s.
05-25-2018, 03:20 PM #20
