Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: wiring....
    Irondequoit Bay, NY
    Default wiring....
    sooo since i took tomorrow off to go to the drag track with my friends and now it looks like its going to pour all day i decided i will re do the wiring in the amp racks..it started off nice but now i was just trying to get it done for this weekend so i could go out and try it..since it will be cloudy and 60's and my head unit and two batteries wont be here till tuesday i might as well take the time to run these wire again...im also going to have to build my custom sub box that will hold my 2 10" polks and a mount for my ZLD...this whole wiring thing is a pain haha..the hardest part so far was running the tower speakers..anyone know of any nice tower lights? the old one i had were from liquid audio and were toast when i took them off...will add pics hopefully tomorrow
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Polk 10in sub (2)
    Polk P330 amp (subs)
    Irondequoit Bay, NY
    well i hooked everything up and i dont know if i missed something but i the motor wont crank and the amps wont power up..im going to try a few things
    Exile XM7's
    Exile Harpoon
    Polk 10in sub (2)
    Henderson, NV
    I'd say you missed something
    Maybe its the batteries that wont arrive until Tuesday?
    J/K! Gives us more info on what the system and battery scheme consisted of before the upgrades and what you just installed.
    Irondequoit Bay, NY
    hooked up all the batteries everything works, fuel will prime but when u turn the key to start it you get nothing
    Exile XM7's
    Exile Harpoon
    Polk 10in sub (2)
    Sounds like the helm BUSS has power but the main starter cable could be connected to the wrong spot or not connected at all. Is the shifter in gear? Kill switch?
    Break out the volt meter start by checking voltage at the main cable on the starter, then the solenoid wire while someone holds the key in the crank position.
    Glad we got the amp figured out last night, i guess with all the Amp stuff we forgot to work the starter issue. Send me a text later if you want me to call you and go over a few things to check.
    [COLOR="#696969"]
    Irondequoit Bay, NY
    will do..knowing me i probably took a wire out or something and forgot to put it back( dont think so tho haha)..i wobder if it could be the neutral switch too
    Exile XM7's
    Exile Harpoon
    Polk 10in sub (2)
    Irondequoit Bay, NY
    im showing 12v to that starter
    Exile XM7's
    Exile Harpoon
    Polk 10in sub (2)
    Irondequoit Bay, NY
    weeelllll i found out what it was..ill upload a pic in a few..would have never saw it if i didnt look up and noticed the little silver hanging out
    Exile XM7's
    Exile Harpoon
    Polk 10in sub (2)
