Results 1 to 10 of 10
05-18-2016, 10:41 AM #1Senior Member
- Apr 2014
- 141
Heater Doesnt Start Unless I Punch It
My Heatercraft Heater worked great last year, but this year when i hit the switch i get nothing. I found that either hand spinning the fan before turning it on, or hitting the heater with a screwdriver or something with the power on, will get it working. so there's a corroded something, somewhere, it seems. Anyone fix this?
I have two calls into Heatercraft where they need to reach the tech guy, who hasnt been available, and no call back...2002 mobius LSV
Lake Minnetonka, MN
05-18-2016, 11:17 AM #2Senior Member
- Feb 2016
- 158
If your smacking the motor, then it will run fine. Then the motor is bad. It has a bad spot in the armature.
2016 Moomba Craz
Gunmetal W/ flake
Atomic Orange Accent
Black Deck and Hull
05-18-2016, 11:45 AM #3
You can take it apart and make sure there are no loose wires or connections anywhere. If it's ok then like Brokeguy said, probably the motor. I just replaced my motor last year, my breaker would keep tripping. It's a pretty easy job to replace the motor.
Scott
2021 Craz
1997 Sea Ray 190
05-18-2016, 12:09 PM #4Senior Member
- Apr 2014
- 141
05-18-2016, 12:21 PM #5
or carry a BFH this season LOL
2015 "NOT A MOOMBA"
05-18-2016, 12:47 PM #6Senior Member
- Apr 2014
- 141
05-18-2016, 01:10 PM #7
I had to replace the heater core in my 98 Moomba and the blower was a single speed motor and looked like the blower in the bilge compartment. The box was riveted together so I had to drill those out. Pretty simple design.
SOLD
05-18-2016, 07:14 PM #8
I mainly thought it was a PITA to crawl under the bow and remove the blower, the water supply lines were really short, so i added length to loop around and connect the heater easily, then screw back to the wall. I had not drained the heater adequately one year and froze the core. have not had any probs with the blower though.
19 Mondo
08 LSV, forever loved
05-18-2016, 09:35 PM #9
05-19-2016, 10:09 AM #10
