Results 11 to 17 of 17
Thread: Amp Ground & ppwer wires?
05-03-2010, 09:21 AM #11
All the better Joe with 4ga in/out for both power and ground. The bigger gauge will help reduce power drop. On a very short run to the amp it's not a big deal but it sure won't hurt. Whatever gauge you do for one then do for the other.
05-03-2010, 10:11 AM #12
Not sure on your setup, but for me with the batteries right by the amps I had no need for a distribution block. I just went 4ga amp to battery on both amps.
05-03-2010, 10:25 AM #13
Brain your correct you dont need the distro blocks for the short runs like mine even. I used the distro blocks because i didn't want 6 amps lines running to a battery.
You have to look at your power and ground lines like a water line. Your flowing current instead of water.
If you got 2 2inch lines flowing water and you Y them into a 2 in single line then what happens? You have back up in your lines. You run the same 2 2inch lines into a Y with a 4inch outlet and what happens? It flows with no issues.
This is the hole idea behind amps and wiring them with a 4 gauge line and a 2gauge supply to the distro. If you are running a 4 gauge line to your distro point and then 2 more 4 gauge lines off the same distro then in fact your asking the battery to supply 2x the current threw the 4 gauge line into the distro.
My system is running 3 4gauge lines out of the distro and i have the option to add a 4th. So i went with a 1o gauge line to the distro from the battery. This is also because im not sure my batteries are going to stay where they are. I might be moving them once i get dry cell or gell cell batteries. I left my system options for more expansion.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
05-04-2010, 03:20 PM #14
I did the same - 4 ga from each amp direct to the battery on the negatives, 4 ga from the battery switch direct to the battery on the positives, with a resettable fuse on each positive wire. Then I went 1/0 gauge or maybe it was 2/0 from the switch to the battery as I could not find 1 gauge.
05-06-2010, 10:29 AM #15
Anyone know what is in the channel behind the spotter seat besides the fresh air vent to the engine. is it something you can screw into at all?
05-06-2010, 10:50 AM #16
Joe if you talking about the big wide vertical channel against the hull then yes, it's hollow.
05-06-2010, 11:08 AM #17
Razz, , yep that's the channel.
as always thanksA Day at the Lake...Priceless
