Results 1 to 10 of 14
Thread: LSV moomba flow?
05-12-2014, 12:15 PM #1
LSV moomba flow?
Just wondering if anyone has installed the flow on an LSV and how well it works.
2008 Mobius LSV
1100#er's in the lockers
ski locker sac
IBS
Johnson reversibles
3 vent heater (which my family loves)
05-12-2014, 03:00 PM #2
I'd like to know the answer to this as well...$1200 plus install seems pretty hefty to save myself waiting a few minutes for the ballast to fill.
I personally would probably pay for the dealer to install and I'm assuming the mod would be about $2k all said and done in that case...in general I trust myself with many modifications to my belongings, but bolting something through my boat hull may be a different story!Boats previously owned - 2000 Supra Launch, 2003 Outback, 2006 Mobius LSV
05-12-2014, 03:06 PM #3
It shouldn't cost more then a couple hours labor. 3-500 tops.
What I found is I can run smaller bags in the rear, saving me room but essentially you are running more weight because you fill both sides on Reg now.
Regular is insane good.
As for Goofy we are still working on it but its improving it and giving it it more length.
Mind you I'm talking Mojo,
I had a solid wave on my LSV both sides, and if the Flow works as I have seen on my Mojo then you will be happy and should be able to run just 1100s in the rear with center and IBS and have a great wave.
On my LSV I was running essentially 1500 rears.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
05-12-2014, 03:10 PM #4Senior Member
- Aug 2011
- 2,522
2006 Moomba Mobius LSV - Sold
05-12-2014, 03:46 PM #5
05-12-2014, 05:20 PM #6Senior Member
- Aug 2011
- 2,522
05-12-2014, 08:13 PM #7Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
05-12-2014, 10:00 PM #8
06-09-2014, 09:43 AM #9Junior Member
- Jul 2011
- Chattanooga, TN
- 19
I have the same question as TL7. Running a bag under the spot where the cooler used to be as well. It's on a 2011 LSV.
Paul - 2016 Mojo - 2011 Moomba LSV (traded)
06-09-2014, 10:50 AM #10
I believe I recall a picture from another thread where this was discussed and it was the bag pushed out the fiberglass (noticeably) so it was worrying. Guess if you have a bag that when filled wont push on the fiberglass, you should be OK.
