Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Aug 2008
    Cottage Grove, MN
    Default Attwood T800 directly to ball valve?
    Was planning to mount a T-800 (from wakemakers) directly to a ball valve to fill my IBS and noticed that the T800 has straight threads and the ball valve has tapered threads. Any issues with making this connection? Attwood makes p/n 4653 which is the T800 with NPT threads. Do I need to get the NPT threaded T-800?
    2006 Outback V - Gone
    2008 LSV - Gone
    2013 other brand
    People do it all the time (though that doesn't make it right). If it were me I'd get the right threads. You probably know this but remember that you can't cut tapered threads shorter so make sure your sizes will work.
    Aug 2008
    Cottage Grove, MN
    Thanks Dan, I think I'll order the p/n with the right threads. Hey thanks again for the pics you sent of your setup. Helped immensely.
    2008 LSV - Gone
    2013 other brand
    No problem, glad the pics helped. Looking forward to seeing some pics of your completed setup. What all do you have planned?
    Is your ball-valve straight or pipe threads?
    Why not just get an adapter?
    Aug 2008
    Cottage Grove, MN
    Not sure I follow but I'm not very knowledgable when it comes to plumbing. Is there an adapter with NPT on one side and NPS on the other?
    2008 LSV - Gone
    2013 other brand
    Aug 2008
    Cottage Grove, MN
    Basic setup is:
    1. iBS plumbed with dedicated fill pump and two drain pumps ( one on each leg). 3/4" lines with separate switch.
    2. 1100's in the rears with dedicated T1200s. 1" lines. Drains are Rule 1100s with one inch lines.
    3. Center bag on dedicated fill pump with 3/4" lines
    Nothing too complicated but some thing that speeds fill times a bit and allows automation of the IBS. Still have to fill a 400 on the seats but not sure how to get around that other than a custom Enzo-style sac.
    2008 LSV - Gone
    2013 other brand
    Aug 2008
    Cottage Grove, MN
    Ball valve is pipe threads as is the thru- hull fitting.
    2008 LSV - Gone
    2013 other brand
    I would assume there is. Lowes carriers tons of different adapters
    http://www.lowes.com/pd_34753-104-A-...RL=&facetInfo=
