Results 1 to 10 of 17
    Lake Amistad, TX
    Default Trailer/Boat on blocks during winter??
    Have any of you thought about jacking up the trailer and resting it on blocks during the winter offseason months to help relieve some stress on the tires!? I've been seriously contemplating this thinking it will help the tires last longer...
    2008 LSV Blue on White
    May 2012
    Memphis, TN
    I will be doing this in the next few weeks
    2011 Supra 21V
    2012 Tundra SR5 Crewmax
    Wetsounds Icon8's
    Jul 2011
    Murrieta, CA
    I don't think it would hurt a thing.
    Jul 2013
    Saskatoon, Saskatchewan
    I have a tandem trailer and would assume I would need to block both axles?
    Jul 2011
    Murrieta, CA
    Quote Originally Posted by drb59 View Post
    That is what I would do.
    Jul 2013
    I have one set so will go buy another as I think it will save my tires
    Aug 2008
    Cottage Grove, MN
    block under the axles or trailer frame rails?
    2006 Outback V - Gone
    2008 LSV - Gone
    2013 other brand
    Jul 2013
    I was going to block the axles. Are you thinking you could just place on the frame?
    I'd suggest just under the axles if you're going to. Had mine blocked up on the frame while doing suspension repairs and spring replacement. Gotta have it up pretty high = more tipsy.
    I'm curious what benefit having the weight off them will bring. I know a lot of RV'ers put covers over their tires to keep them out of the elements - both sun and rain. Protects the sidewalls, prolongs the life.
    Aug 2008
    Cottage Grove, MN
    This is probably a silly thought, I just didn't know if the axle body/frame itself could take the weight or if it might somehow deform the axle. I'm guessing it wouldn't, but that's one of those things that I would surprise me AFTER I make the mistake
    on my old trailer I blocked the trailer frame itself to replace an axle, but as bergermeister points out, you need about 21" or so to get it off the ground.
    2008 LSV - Gone
    2013 other brand
