Results 1 to 5 of 5
    Feb 2021
    Lexington, KY
    Default Cruise, Speedo, Tach stop working
    22 Mondo
    While under power the cruise, Speedo and tach all lose signal and read 0. Fuel reads 0.
    Boat remains under power and radio works.
    Turn off and back on and sometimes it comes back, sometimes it doesn't.
    Sometimes it will come back while under power.
    Any clues?
    2022 Moomba Mondo
    Mar 2021
    South Georgia
    Sounds like something loose. Check all connections starting with grounds first. A majority of electrical problems are ground related. Even the negative terminal connector on the battery.
    2021 Moomba Makai
    Feb 2021
    Lexington, KY
    Thanks. I'll check the battery connections as I didn't find anything loose under the dash.
    2022 Moomba Mondo
    Feb 2021
    Lexington, KY
    Found a loose aux battery cable.
    Thanks friend.
    2022 Moomba Mondo
    Mar 2021
    South Georgia
    Quote Originally Posted by SSurfer321 View Post
    Thanks friend.
    Sweet. Glad it solved the problem. Grounds are almost the root of all electronic related problems in some fashion. I love that feeling that comes with discovering what you think might be an expensive problem turns out to be just a simple tightening of a nut!!
    2021 Moomba Makai
