Results 1 to 2 of 2
    Default Vib @ Slow Speeds - Better Prop Pitch, Blades?
    I have a 2000 Kanga and spend most of my time skiing. My wife prefers to wakeboard and I've been doing a lot of driving at 20mph pulling her. The problem is that the boat doesn't plane particularly well at 20mph and it has a bit of a vibration or rough ride.
    I am going to start with a new prop, hoping that I can solve two problems at once. (1) Possibly to repair any potential imperfection causing the moderate vibration. (2) achieve a better plane/consistent feel at slow speeds. (3) possibly holding the most consistent speed (as I've also read in this forum the 4-blades offer).
    This thought was based on an email I read by Brian Raymond in an earlier thread. He mentioned that a four-blade will cause the boat to ride more level at slower speeds.
    Assuming this to be true, my only question is whether I can purchase a different pitch that will also improve the Kanga's ride at 18-34mph. I don't care about speeds above 36mph whatsoever, so the top-end isn't an issue. Also, the hole-shot isn't an issue - the Moomba is great in this regard.
    With this in mind, is there a better pitch for me? And can anyone suggest whether something like the Acme CNC four blade to be a good option in this instance?
    Thank you in advance!
    Aug 2002
    Bismarck, NorthDakota
    Default Replying to Topic 'Vib @ Slow Speeds - Better Prop Pitch, Bl
    I bought a cutter 13x13 4 blade Stainless steel prop that I am happy with.
    As for the vibration, if you take it to a shop have them check the shaft alingment.
    Bruce Fuerstenberg
  1. WAKEBOARD PRO PROP VS STANDARD MOOMBA PROP
    By DMON in forum General Chat
    Last Post: 05-14-2007, 10:14 AM
  2. Some Strange noise at low speeds
    By superman in forum Service & Repair
    Last Post: 07-06-2006, 07:37 AM
  3. Now I'm slow
    By pullmyfingers in forum Skiing & Slalom
    Last Post: 07-28-2005, 04:34 PM
  4. Porpoising (SP?) at higher speeds
    By cola in forum Boat Owners
    Last Post: 08-25-2003, 02:10 PM
