Thread: Winterization
    Oct 2002
    Salt Lake City, Ut
    Default Winterization
    I'm getting ready to winterize my boat. I've heard that instead of draining all the water from the engine, it's better to pump it full of antifreeze. Does any one have any recomondations on this?
    Aug 2002
    Maryville, Tn.
    Default 2 cold 2 boat
    Vdawg, be very weary of useing antifreeze with all of the EPA stipulations, your local dealer should be able to properly winterize your boat and add the proper amount of fuel stabilizer. If attempting to conquer the task solo, check with your dealer on helpful tips and reccomendations. Indmar is very helpful in this area also. Brian Raymond
    Aug 2002
    Bismarck, NorthDakota
    Go to www.indmar.com for a manual on winterizing your engine.
    Bruce Fuerstenberg
    Jul 2002
    London Ontario Canada
    After you drain you motor re indmar specs you can pump plumbing antifreeze into the drain plugs until it drains out the water pump (after you've disconnected the hose) at the front of the engine. plumbing antifreeze is enviromentally safe.
    N.B. ALSO IF YOU HAVE BERTHA BALLAST PUMP THIS INTO YOUR EXHAST PORTS AS IF THERE IS ANY WATER IN YOUR DRAIN PUMPS IT CAN FREEZE AND CRACK OPEN YOUR PUMPS !!!!!!!
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Guest
    Default Spring / Fall low temps
    OK, I read the posts and the owners manual. Where I live it is not uncommon to have subfreezing temperatures well into May but there are good lakes at the lower elevations I can hit in March. What precautions should I take during the "iffy" months when I want to use the boat but am afraid of having something freeze during the cold nights.
  1. winterization
    By NC05LSV in forum General Chat
    Last Post: 10-04-2007, 08:04 PM
  2. First time out after winterization
    By Chief Hawkeye in forum Service & Repair
    Last Post: 05-24-2006, 12:35 AM
  3. Do I need winterization?
    By marchina in forum Service & Repair
    Last Post: 08-25-2005, 11:19 AM
  4. Why change oil @ winterization
    By in forum Service & Repair
    Last Post: 11-17-2004, 10:04 PM
  5. winterization
    By BUSHSTER1 in forum Boat Owners
    Last Post: 12-11-2003, 02:38 AM
