Results 1 to 10 of 14
Thread: Ballast bag filling slow.
11-24-2009, 02:51 AM #1Junior Member
- Aug 2009
- 19
Over the summer i noticed the rear portside bag would always fill very slow.
after doing a little research i found that my system uses one big pump to fill all the bags. so why would only one bag fill slow.
ow yea this is on a 2005 xlv with gravity 3 ballast system.Last edited by yotaismygame; 11-24-2009 at 04:03 AM.
11-24-2009, 11:15 AM #2
Maybe the check valve for the air vent is buggered?
11-24-2009, 12:22 PM #3
Check the sprinkler valve for that bag, could have an obstruction or the valve might nor be performing 100%.
11-24-2009, 01:41 PM #4
2nd on checkin that sprinkler valve
Hey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
11-24-2009, 06:40 PM #5
if you need to replace valve there only $10 or so at Lowes or Home Depot. Not expensive to just buy one, replace it, and see if it helps?
2015 "NOT A MOOMBA"
Why Not? Play Hard! Get wet
11-25-2009, 04:03 AM #6Junior Member
- Aug 2009
- 19
Im not real savy with this ballast system yet, the sprinkler valve is under the rear seat right? And to check it i would need to take it apart and look for............
thanks for the help i reall appreciate it.
11-25-2009, 04:16 AM #7Junior Member
- Aug 2009
- 19
http://www.wakeworld.com/MB/Discus/m...tml?1232213575
I think iv got it figured out. Ill take it out and have a look inside.
11-25-2009, 08:17 AM #8
try this one https://forum.moomba.com/showthread.php?t=7352&page=2
I had taken some photos of the valve being disassembled here. very easy to do. Your valves should be on top of the V-drive unitHey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
11-25-2009, 04:32 PM #9Junior Member
- Aug 2009
- 19
So looking at that thread you posted, has any one noticed any cons to removing the springs?
11-25-2009, 06:41 PM #10
If i remember a couple peeps said the water got through without them.
