Results 1 to 10 of 15
Thread: Stabil
    Default Stabil
    I was wondering because i am going to need to do this very soon.
    I still havnt winterized my boat yet. I know i can see the looks of shock, disbelief, and what the hell are you waiting fors? LOL
    My garage is heated and even last week when we were below 30 my garage was a warm 47 degrees.
    Anyhow i have drained all the water for the boat and done everything except put stabil in it.
    Question is, should i put it in the fill the boat with fuel? Or fill the boat with fuel and then all Stabil?
    I know some feel you need to add it then run the engine to let it circulate. I can see you thinking here because the 08 Fuel pumps are outside the tank. Being a Fuel injected engine the fuel system is under pressure all the time and i don't see how water is going to get in my fuel lines. I can start the boat and let it cycle if its realy needed. I would have to re-drain all the water again.
    So do you think i need to add Stabil before or after fueling?
    [COLOR="#696969"]
    Henderson, NV
    I add it to the fuel after filling it up. I figure that the trip home will mix them completely. you're not trying to prevent moisture in the lines, as you stated they are pressurized, it's the tank where you will get the buildup. that's the logic behind filling it completely full.
    I suppose that in the end, it really does not matter whether you add it first or last. end result will be the same.
    Nov 2003
    Land O Lakes, Florida
    I add stabil and then fill it up with gas, as the gas enters the tank it helps mix it up
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
    Oct 2009
    Modesto, CA
    I always add it before the fuel that way it mixes as the fuel fills the tank. Filling the tank all the way prevents any air space for condensation to form and keeps water out of the fuel.
    Apr 2008
    California
    Same as 'Daze but make sure to run it for 10 minutes or so after adding to distribute the Stabil throughout the fuel system.
    Aug 2009
    NorCal
    Stabil or the Marine Formula Stabil? Think I'll fill er up this wknd and pull the batteries.
    2009 Moomba Mobius XLV: 340hp, bimini top, Kenwood speaker system with sub.
    Sep 2009
    Pensacola, Fl
    I always put it in before filling up just to help with mixing it all together.
    Anyone know the difference between Stabil and "Marine" Stabil, other than the marine version costs more $? Probably has to do with some advanced polarized centrifugal additive configuration that will magically make your engine run better. lol
    Apr 2008
    California
    I'm guessing it has something to do with boats used in salt water as there's a lot of stuff made "marine" that fits that criteria. I've always used regular Stabil without issue in fresh water.
    Jul 2002
    London Ontario Canada
    Stabil helps prevent the degredation of fuel which begins immediately and can lead to a problem in gas 30 - 90 days later depending on quality of fuel. you want to run it through your entire fuel system to maximize its effectiveness. fuel sitting in bowls and small carb passage lines , injectors, etc . fuel allowing to sit will evapourate leaving gum deposits and plugging things.....its good prevention to add when fuel is going to sit longer than 60 days... so mix with gas and run for 10 mins
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Jan 2009
    Salem, OR
    I just had my boat serviced at 25 hrs and I now have 50 hrs. I keep my boat in the garage. Do I have to winterize? My last boat was an I/o and I would winterize every other year.
