Results 1 to 2 of 2
11-17-2009, 01:29 PM #1
found in the center ballast compartment
so in the process of figuring out where to run cabling for the stereo, I was snooping in the center ballast compartment. this thing normally fills up completely full with water to the point that it can push open the center locker door if you let it "overfill". anyways, in my search, found these screws pointing down into the center locker. don't know how they haven't punctured a bag yet, but they are from the pass. seat supports. they hang down into the center locker over an inch. there's more from the battery tiedowns and other odds and ends, but these are the worst.
guess I found my next project to replace with right-sized nuts and bolts.
sorry for the crappy pic, but it's with the camera down inside the locker looking up at the floor..
11-17-2009, 01:33 PM #2
Wow ill have to check mine out as well. When i took my center bag out it had a huge scratch down it. Cut threw the grey colored material and the back bag bladder is showing. I thought it was from some fiberglass over hang when you open the ski locker. I filed it all down smooth.
Ill look for these screws and such.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
