Results 1 to 10 of 17
    Default Amp wiring question
    This is probably a dumb question but here goes. If my amp is rated at 100W per channel at 2 ohms and I wire two 4 ohm speakers in parallel to one channel so that the amp sees a 2 ohm load, does each speaker receive 100W or 50W?
    Thx,
    Al, I believe it would be 100w but here's and article that goes through the calaculation
    http://www.termpro.com/articles/spkrz.html
    correction 50 w each speaker ( i was using the 8 ohm Speaker load)
    Mar 2008
    If you have a 4 ohm speaker wired to one channel of the amp, positive to positive and negetive to negetive then the amp sees 4 ohms. So in this case you will only be putting out 50w.
    Now if you add a second 4 ohm speaker to that channel, with both positives of each speaker to the positive post on the amp and the same with negetives, then your amp would see a 2 ohm load.
    The only way to change that up is to have 2 ohm speakers.
    Here is a good online reference.
    http://www.colomar.com/Shavano/spkr_wiring.html
    PWI as usual...
    newty, question? ( excuse my ignorance)
    how are most tower double ups wired for the tower, series or paralle and what do most people run them from 2 channelsat 2 ohms or 4 channel amps at 4 ohms?
    also, how are the cabin speakers wired from the factory series or parallel?
    I don't see too many speakers besides subs that handle 2 ohm loads?
    De Pere WI
    the questions you pose above depend on the speakers and amps. there are not many 2ohm door speakers, but they do come in 3, 4, 6 and 8ohm variants. how you wire them depends on how many speakers you plan to run and what the amp you are using can be configured for. I am planning on running the hollow points wired in parallel and a 2ch amp stable to 2ohms stereo. you could also run a 4ch amp and run it bridged, but most 4ch are not 2ohm stable bridged unless you spend some coin, and you would not get the same bang for the buck in series for an 8ohm load bridged.
    not sure how the tower speakers are wired currently, but it's not hard to tell if you pull one side out. my in-boat speakers were wired with the bow on 2 channels and the 4 in the main lounge wired in parallel to the other 2 channels. presents a 4ohm load for the fronts and a 2ohm load for the main cabin on the 4ch amp(assuming they are 4ohm speakers, which I believe they are). my guess is this is how most of the boats are wired.
    De Pere WI
    and if you really want to get cute, some of the old school "cheater" amps are stable to .5 and .25 ohm loads. you can run an entire boat off one orion hcca225. rated at 25x2, but realistically more like 3-400x2. you start getting into runnning full range speakers in stereo and run the subs mixed mono across both channels. impedence gets real tricky then
