Results 1 to 10 of 17
Thread: Bare footin prop
10-12-2009, 09:05 PM #1
Bare footin prop
I just ordered a new mobius ls. The dealer said when it gets here (Calgary A.B.) we would take it out and decide at that point what prop I would like on it. It's my first ski boat but my father had 2 nautique's and a supra. I really enjoy long line footin and slalom skiing. I need to hit atleast 40mph and would like to hit 45 if possible..anyone know what prop i should get?
I dont want to much rooster back there either.
I never see anyone talk much about barefooting on this site.
10-12-2009, 10:34 PM #2
not to rain on your parade, i had an 99 outback ls that would do 44 with the standard 3 blade prop . now they all have cnc props but they changed the hull design since then. I was debating getting a new barefooting specific boat like a sanger maybe even the v drive as it is the same hull and the prices are very reasonable on these right now. the wakes behind these boats are the best for footing. did you get the 340 or 409 motor? i'm getting older and will prob do most of my footing off the boom so i decided on a supra 21v more for the surfing now and comforts. I had no problems with my moomba and it was a great boat but if your really into footing a sanger dd or 210v or an 05 or earlier malibu lxi with a hammerhead is the way to go.
You should look at barefootcentral for info and reviews, ya might want to try and get out of the current model .
happy boating and good luck
10-13-2009, 12:53 PM #3Senior Member
- Jan 2008
- Pensacola, FL
- 1,585
If you are into footing, you really must get the 409 engine. You will not be happy with any prop that you use as everything is a compramise. My 08 Outback is running WOT just to maintain 40-42 while footing. A prop will only lower my initial pull for slalom, which is already weak enough.
1997 MasterCraft 205
2008 Moomba Outback
1999 MasterCraft Sportstar OB
1992 MasterCraft 205
1999 Malibu Response LX
1987 Marlin Magnum Skier
10-13-2009, 08:16 PM #4
this is quite funny
Not to be a jerk or anything but everyone and there more power comments....is there a e
realist out there that has been skiing for over ten years. I mean come on I started skiing behind a 76 nautique. It had a merc with 233hp and we foot behind it went through the course and everything you could emagine. if you cant do well with 325 hp there is an issue i just want more top end speed I am willing to sacrafice the hole shot........please someone with somthing more to say than "You should have gotten a v drive " or "you should have gotten more power" A v drive is the last thing you want for barefooting. I have barefoot behindbarefoot nautiques and to be honest the hole shot was nice but Our 92 supra had easily as nice and soft of a wake..
Please someone with some experience in an ls and prop sizing HELP!!!!!!
10-13-2009, 09:11 PM #5Senior Member
- Jun 2007
- Calgary Alta Canada
- 926
Curious to know what your top end is or expected to be with the stock 3 blade prop.I'm in an Outback DD with the stock upgraded cnc 3 blade prop,not sure of the numbers right now but as mentioned above 42,44mph WOT,thats it. Have you talked to OJ or Acme directly as i think they are the ones you really need to talk to. In and around Calgary with the higher altitude 3500ft that may be all your going to get.I ski my boat mostly and the holeshot is decent,so maybe there is a prop that will give you more mph and not hurt the holeshot too much.
I have the 325 motor but my boat is a little lighter than the LS also.Post results if you get some good advice ect.
10-13-2009, 09:52 PM #6Senior Member
- Jan 2008
- Pensacola, FL
- 1,585
Your 1976 Nautique was a 19' boat with little to no interior; it was also an 80" beam. This all translates to much less running surface in the water. Less drag means you can use less power to get to a certain speed. An Outback is 20.5' with an 88" beam, and it has a lot more running surface. An LS is another foot longer!
I started skiing (learned to barefoot there) with USF in '93 and bought my first boat in '95.
Most of my comments are based on you ordering a new boat. If you are spending that much money, you really should get exactly what you want. Can you barefoot in a stock new boat? Absolutely! Will you be pushing that boat to it's limit all of the time that you are footing? Absolutely! Given a choice, you should equip your boat to the activity that is important to you. Because I don't foot much, I just use a boom and short line, so I can use a little less speed.
2008 Moomba Outback
10-13-2009, 10:14 PM #7
Thankyou!
I understand that the boat will be larger and have more surface tension. do you really think that It would eat a bunch of hp up?
That I dont know but I bought the ls because I slalom and wakeboard during the days and usualy finish a good day on the lake as the sun is falling and moon rising when the water is like a sheet of glass barefooting for an hour or two.
So this is why i got the ls......you think the extra hp is huge? Really?
I appreciate you reading this and taking the time to post back.
10-14-2009, 02:45 PM #8Senior Member
- Aug 2007
- Toronto, Ontario
- 187
The top speed my 2007 Outback increased to 48mph with a prop change. I now use a 13x12 ACME 3 blade. That should be plenty fast enough for barefooting.
2007 Moomba Outback
99.999% Slalom, 0.001% Wakeboarding
10-14-2009, 03:04 PM #9
13x12?? You sure it's a 12 pitch? That's quite a bit lower than the stock 17.5 which should have reduced top speed significantly.
Al
10-14-2009, 03:50 PM #10Senior Member
- Jan 2008
- Pensacola, FL
- 1,585
Just so you understand props:
13x13 of 14x17 are a few ways that props are measured and described. The first number is the diameter of the prop. A standard for ski boat is 13", but ski, wake, and trick boats will vary from that. The second number is the pitch of the prop. The number is the number of inches that prop should push the boat per revolution. The higher the prop number, the faster the top speed; the lower the number, the better the low end pull. Everything is a compromise when making changes. Props can have different cups and blade configurations to compensate for things. It is best to talk to the professionals at OJ/ACME or SC about the best prop.
Props can't create HP or TQ, that is all engine. If you look at Sanger, MC, or CC, they do (did) higher HP motors, geared transmissions, or a combo to make their boats barefoot friendly. MC made outboards in order to get the speed and wake combo best for footing.
One last thing on HP, no one has every driven a ski/wake boat and said, "Gee, I wish that I had less power" or "I should have ordered the smaller motor".
Do an internet search on the coefficient of drag and hydrodynamic and you will see that a few MPH at high speed will cost you an exponential amount of HP.1997 MasterCraft 205
2008 Moomba Outback
