Page 5 of 5 FirstFirst ... 345
Results 41 to 43 of 43
  1. #41
    Aug 2009
    Montana
    Thanks -- that helps alot!
    I think I have 1 break that both batts go through. I'll have to double check. I might add a second
    2015 "NOT A MOOMBA"
  2. #42
    David,
    I have the Blue Sea Add A Battery ACR installed - any compatibility issues between it and the ProSport 20?
    Thanks,
    David,
    Also, I only have two batteries at the moment but could see the possibility of adding a third in the future if I decide to go with three amps. With that in mind, could I use the ProSport 20 Plus with just two batteries so that if I do decide to add a third in the future, I won't have to upgrade the charger? Or does the 20 plus require three batteries to operate?
    Thanks,
  3. #43
    Jul 2019
    If you let the batteries sit for a while and don't trickle charge you might have an issue. Always use trickle charge if you haven't used the batteries in awhile.
