Results 1 to 6 of 6
    Default Changing out prop on 2006 Outback V
    Is there any special tool or anything I will need to change out my prop? Also the new prop is 14.25X14.50, the old one is 14X14.25, does this matter?
    Sep 2005
    Claytor Lake, VA
    you'll need a prop puller. use anti sieze when you install the new prop. don't usually see that size prop. why the change?
    That is the size OJ props sent me. Will it not work?
    Sep 2005
    Claytor Lake, VA
    should work fine. something wrong with your original or do you just want a spare?
    One of the blades fell off at 48 mph on Lake Mead. Did not hit anything! I will try tpost pictures of it. OJ sent me a brand new one with NO arguements.
    Here are the photos of my prop!!!
