Results 1 to 8 of 8
Thread: 2005 Moomba LSV
09-17-2009, 09:46 AM #1Junior Member
- Sep 2009
- 8
2005 Moomba LSV
We found a used Moomba that we really like- It's a 2005 with only 74 hours on it- I've heard that either 2005 or 2006 it was redesigned to make it deeper-(still thinking about those rough waters). Does anyone know which year that actually occured?
09-17-2009, 10:28 AM #2
I am pretty sure it was 2006.
09-17-2009, 11:26 AM #3
05 lsv
I have one and often thought about if if I should have purchased an 06 or newer. I have had the boats side by side in the water and the difference is noticeable. The 06 is deeper , wider , and longer . There is more room in the back storage areas beside the engine, I think you can actually fit a wake board in there on top of the ballast bag. The tower is different , you can stand up in the boat and not hit your head on it if you are 6' or taller. The seating is better , it doesn't feel like you are sitting on a cushion on the floor.
Big water: I have had mine on lakes with pretty good size waves going into them in all directions and have had a little water over the bow a couple of times. If you keep on the throttle and keep the bow up they do pretty well. So if you get caught out you can get back to shore/ramp safely if you know how to drive the boat. Another advantage is the 05 lsv is shorter and narrower , less boat to handle and wash , clean , etc. My 2 cents.
Jim.05 Mobius lsv , ballast system , stereo, etc..
09-17-2009, 12:02 PM #4Junior Member
- Sep 2009
- 8
05 Lsv
A dealer I spoke to said the old LSV is the same size as the Outback? Does that make sense to you?
09-17-2009, 12:07 PM #5
I believe I've heard before that the current OBV is essentially the same hull as the old (2005 and back) LSV hull.
09-18-2009, 04:05 PM #6www.louisianawakeboarding.com
2004 LSV
Perfect Pass, Integrated ballast (front, rear, middle), Wake Plate, Tower mounted bimini, Swivel board racks, Surf board rack, Tower mounted mirror, Keel guard, 4 tower speakers, 12" sub, 2 amps, transom remote, Bow filler cushion, and the list continues to grow.
09-18-2009, 08:27 PM #7Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
I have an 05 LSV, bought it new. It now has about 300 hours.
It is not a great boat for really big water. My lake is 7 miles long but I don't go out in really big swells. 2-3 foot are fine but after that it is not fun. I've never feared for my life and only once ran from the wind -that was in my 18 foot Lund - turned out to be the Huricane leftovers -- 70 MPH+. It was a short run and not really much more than not fun.
I really like my boat but if I were buying today, I'd get the newer LSV. It is a nice boat.
As far as rough water - the margin between the two Moombas is too small to bet your life on. If I stayed home with one, I would stay home with the other.
09-19-2009, 11:08 AM #8
05 lsv is the 06-08 outback v I had my 07 obv next to a 05 lsv and they are identical
I have had my boat in some nasty water and it does ok just have to go slow and be careful but the same can be said for any boat2007 Outback V
