Results 1 to 10 of 20
Thread: 06 LSV Top Speed?
09-09-2009, 07:04 AM #1Senior Member
- Jun 2007
- 883
06 LSV Top Speed?
I have a 06 LSV, I can get to about 36mph no problem, but past that feels like I am really pushing the boat...
about what RPM should I be at around 36 mph... and what should my top speed be?
i assume i have a standard prop (or standard wakeboard prop), but i did buy the boat second hand.2006 Moomba Mobius LSV
Stereo: Kenwood KMR-D562BT
Ballast: 750 Surfside locker, 400 Surfside mid boat, 400 Gravity I, 400 Bow
Surfboards: Inland Surfer Red Woody, Triple X Composite X 58"[/SIZE]
09-09-2009, 07:07 AM #2Senior Member
- Jun 2007
- 883
by the way, I have the 325 engine.
I just wanted to make sure this is normal...2006 Moomba Mobius LSV
09-09-2009, 07:50 AM #3
look on the backside of the prop and you will/should see some numbers stamped in it-this will be the size your prop is.
Hey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
09-10-2009, 06:07 PM #4Member
- Jun 2008
- Aurora, IL
- 41
I have an '07 LSV with the 325 and wakeboard prop. At wot (around 4800 by memory) I get around 37-39 mph depending on how many peeps and gas are on board as well as how the boat is trimmed with the wakeplate.
09-11-2009, 07:47 AM #5Senior Member
- Jun 2007
- 883
thanks guys, that sounds about right with what I'm seeing
09-13-2009, 10:46 PM #6
normal
I have 14.25x14 OJ and 36-39 is tops..Brad
2006 Moomba Mobius LSV sold
2004 Outback sold
09-17-2009, 12:35 PM #7
top speed
Moomba lsv 325hp , 13.5 x 16 acme , 40 maybe if I can keep the boat from porpoising too much. 13.7x 17.7 oj, better at low altitude with a light load about the same speed . rpm is 4800 maybe , again the boat porpoise's too much and with various wake plate positions and boat loading. Jim
05 Mobius lsv , ballast system , stereo, etc..
10-10-2009, 11:57 PM #8
spyder,
I have the same boat with the same engine as you and today, I got it up to 42 mph at 5000 rpm, full tank of gas, one adult and one kid on board, wakeplate about halfway down to keep it from porpoising. This was verified with a portable GPS unit I had with me. I have the stock OJ prop (13.7x17.5).Al
10-13-2009, 11:13 PM #9
i have an 08 lsv with the wakeboard prop. i had empty tanks and the wake plate about 7/8 down on a glassy morning & my perfect pass said 40.2 mph. i typically only hit 39 at best - i must have had ideal conditions.
you have the right to remain silent so shut the hell up!
http://www.wakesiderides.com/rides/i...ge=out&id=3213
http://www.wakeboatowners.com/tprkolbas
10-13-2009, 11:32 PM #10
Glad to hear it since I am thinking about upgrading to a wakeboard prop. Is your PP calibrated?
Al
