Results 1 to 3 of 3
Thread: bent strut
    Apr 2004
    Default bent strut
    can I replace a strut my self? Can a bent strut be straightened and how much does a strut cost and how much would it cost to have it done if it is truley only the strut
    Apr 2004
    Default Replying to Topic 'bent strut'
    YES YOUR BENT STRUT CAN BE BENT BACK DEPENDING ON THE SEVERITY AND DEGREE STRUT IS BENT TO. I JUST HAD MINE FIXED ALTHOUGH I HAD TO GET A NEW STRUT I WAS ABLE TO BEND BACK THE SHAFT WHICH ALSO MAY BE A PROBLEM SO CHECK THAT AS WELL
    Apr 2004
    TO ANSWER THE QUESTION TO CHANGE THE STRUT YOURSELF IS A VERY DIFFICULT TASK BECAUSE YOU HAVE TO NOT ONLY CHANGE THAT BUT CHECK THE ALIGNMENT OF THE SHAFT WHICH UNLESS YOU ARE A PROFESSIONAL I THIS FIELD IT WILL BE VERY HARD
  1. Strut bearing
    By rosh in forum General Chat
    Last Post: 05-03-2007, 08:25 PM
  2. Bent prop, strut and shaft
    By Rugburn in forum Service & Repair
    Last Post: 07-29-2006, 11:41 AM
  3. Bent rudder..........How much $$$
    By jeffreyala in forum Service & Repair
    Last Post: 07-05-2005, 07:24 PM
  4. strut alignment
    By mmoody in forum Service & Repair
    Last Post: 04-21-2004, 11:43 PM
  5. Drive shaft Strut bearing
    By Yellowmobius in forum General Chat
    Last Post: 09-08-2003, 07:16 AM
