    Jul 2003
    Carson City, NV
    Default Drilling into fiberglass
    Does anyone have any advice (do's/don't's) for drilling/cutting holes in fiberglass? I'm installing a wake plate and guage. I'll need to cut/drill a 2" hole for the guage and a variety of 3/8"-9/16" holes in the transom for the wake plate. Don't want to crack or chip the gelcoat or do a sloppy job. Thanks for the help.
    Jul 2003
    Default Replying to Topic 'Drilling into fiberglass'
    Make sure to put tape around the area you need to drill and then drill through the tape. This will help with cracking and make a cleaner whole. I believe most people just use duct tape for this. Same thing for the 2" hole, except find the center and start a pilot hole with a smaller drill bit before you use your cut out bit.
    Jul 2002
    London Ontario Canada
    for the smaller holes put the drill in reverse to go thru the gel coat to prevent cracking. Ive used a drill lauger than the final diameter to bevel the gel coat about 1/16 to 1/8
    inch deep then drill my hole size thru the fibreglass in forward direction. not sure about the larger hole but would suggest going backwards untill thru gellcoat and slowly like suggested by carsondoc and tape and pilot re lowdrag.
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Jul 2003
    Carson City, NV
    Thanks to all. I really appreciate your help.
    Nov 2003
    Texas
    After you drill the hole. bevel the edges so you dont have cracks starting from sharp edges.
  1. Crack in fiberglass
    By JDsTOY in forum General Chat
    Last Post: 11-05-2007, 07:45 AM
  2. Drilling through fiberglass...any advice?
    By iaonbb in forum General Chat
    Last Post: 03-05-2007, 04:48 PM
  3. Drilling Tower
    By AZHeet in forum General Chat
    Last Post: 07-15-2006, 05:35 PM
  4. Gas Stains On Fiberglass
    By pss3757 in forum Boat Owners
    Last Post: 07-29-2004, 03:08 PM
  5. fiberglass scratches
    By Keaton in forum Boat Owners
    Last Post: 03-11-2004, 03:00 AM
