08-13-2009, 12:07 PM #1Junior Member
- Aug 2009
- 6
ignition circuit breaker keeps popping
help 2000 moomba outback runs for about 15 seconds then ignition cb pops. any ideas ? everything else appears normal.
ok just went back to boat after about 45 min and it seems to have fixed itself. im thinking maybe some moisture ?
well its 2 days latter problem returned. got back to dock now boat will not start.
helpLast edited by fmcmanus3rd; 08-16-2009 at 03:13 PM.
08-20-2009, 03:11 PM #2Junior Member
- Aug 2009
- 6
its not the c/b
just bypassed c/b with spade type 20 amp fried it in 7 sec its on the way to the dealer
08-22-2009, 08:42 PM #3Junior Member
- Aug 2009
- 6
bad fuel pump
brought it to dealer they say it had bad fuel pump that was shorting out. thats why the c/b popped.
got it home tried starting and fuel just pored into carb. called dealer he says i must have contamination . i think the new fuel pump is the issue? now it goes back monday.
08-26-2009, 01:48 PM #4
Please keep us posted.
05-23-2010, 02:10 PM #5Junior Member
- Aug 2009
- 6
stuck float in carb
ok brought back to dealer they could not find problem. They opened the carb and found float was a bit sticky. I think the 40 miles each way of towing on back roads and an empty carb may have bent something internal. working fine now
