Results 1 to 10 of 15
    Jan 2009
    Calgary, Alberta
    Default Technical Help Needed
    So here we are...day 1 of our 2 week vacation here on the Flathead Lake in Montana.
    I have a 2004 XLV with the 340 HP Indmar. I know I have vapor lock issues but today was totally different.
    Actually it started yesterday. Dropped the boat in the water and the kid took it for a "bit of a stretch" as he likes to call it. Went hard for about 5 minutes and then pulled into the slip at the place we rented. Approximately an hour later we went to go and the boat wouldn't start. Giving all the signs of vapor lock (start, quit, start, quit). Waited moire than another hour (trying periodically) and all of a sudden it went. We headed out on the lake, played for about an hour, starting, stopping, idling, etc, with no problems.
    Today we hit the water around 12:00 noon. Pulled out and headed across the lake at a pretty good clip (about 25 mph). We cruised at that speed for about 45 minutes until we reached the other side. Shut it down for a bit, had a drink and then decided to do some surfing.
    Now we have learned from you fine folks on this forum how to beat the vapor lock issue on the 340 HP Indmar. We run the blower all the time and as soon as we stop we always lift the engine hatch. I've even wrapped the fuel pump with a cold towel. So far this season we haven't had a problem.
    This time, like the night before, it was giving symptoms of vapor lock. Again we waitied (trying periodically) and after close to an hour and a half of floating around it all of sudden started and ran strong.
    So we headed immediately home, crusing for about 45 minutes until we reached the other side. We pulled up the throttle to idle and the boat started to labour, run rough and eventually die. This time we tried everything and after 2 hours pretty much gave up (the engine bay was cold and the only thing hot was my temper - because you have a boat load of people).
    So I looked for the nearest shore and decided to dig out the paddles. However, prior to doing that (and I admit it wasn't smart and more due to the fact I was mad as hell) I started doing the start (it would run for a few seconds) and I'd put it into gear before it died. This would give me a couple turns of the prop each time before quitting. I continued this for about 20 minutes, moving toward the shore a few feet every time, when all of a sudden it started, ran strong, and took off like nothing happened.
    I know the Moomba owners and this forum have been great for me and I'm hoping someone has a solution for me. I don't know if it's vapor lock, bad fuel of something wrong with an aftermarket fuel flow meter (Navman) the previous owner added.
    HELP, HELP, HELP - thinking of pulling it out of the water and heading into Kalispell hoping a local marine shop might help.
    Anything you can suggest to salvage this vacation will be great.
    Thanks.
    DDL
    Henderson, NV
    there's an additive that you can buy, either from a marina or maybe the local auto store that helps the ethanol-blended fuel. kind of spendy but worth the try to as you say salvage the vacation....
    really sounds like vapor lock, but maybe a filter? if you have the 1hr and tools, might want to change it out.
    last time it happened to me, I dumped 3/4 bottle of water(the 16oz dasani kind) directly over the fuel pump, located on the left side of the engine and it went away immediately. blower all the time and lid up when parked on a hot day has fixed it for me.
    good luck...
    flathead is beautiful.. lived there for a year. side note, did the guy finish the big house on the island just off the shore of lakeside? he had seaplanes that pissed everyone off as he flew in and out in the middle of the night...
    montana bar and grill just ouside lakeside and mooses saloon in kalispell ftw
    Jan 2009
    Calgary, Alberta
    Thanks for the suggestions, I'm going to try both.
    We got back to the house around 6o PM and had dinner. Went out to try and start it (remember it was running fine and we made it home) and it did the same thing again (start then quit after a few seconds). The boat had been sitting in the slip for almost 2 hours. I just went out to cover it up (it's now 10:08 pm) and it fired up and ran like a top.
    Weird!
    The house on the island is actually where we went when we cruised across the lake. Still under construction with lots of equipment and activity going on. I can't tell the difference from the outside so it must be all interior work. Quite the palace for sure.
    Thanks again
    DDL
    Apr 2007
    Las Vegas, Nevada
    It sounds more like a fuel pump issue. When my boat vapor locked, it did not start at all. The engine just turned. The boat was new and I did not know what it was. I would take it in to the dealer and have them check it. It could also be the fuel filter. How long was the boat sitting without beeing used? Did you use Stabel in the gas tank? When was the last time the plugs were changed? I am just trying tonarrow down the problem.
    Tazz
    Mar 2004
    Wylie, Tx.
    Mine was the winter blend fuel. Once all that was out, it ran fine although when it happened to me, it would not start once it ran rough for a few seconds since the vapor was in the fuel rails. On a carb, I don't know how I would go about narrowing it down. To me, it sounds like the fuel pump. Good luck.
    I'm with Tazz here. Sounds like a bad fuel pump. It shows these characteristics.
    Starts in the AM - after its been sitting for a long time.
    Runs great for 1 to 2 hours or shut off.
    Has to sit for 1 to 3 hours to restart again.
    Then the cycle starts over.
    Vapor lock isn't this predictable.
    Sounds like the fuel pump is running hot and as long as its pumping it stays running and when you shut it off its over heats, as the fuel is what keeps it cool internally.
    Id be looking at getting the fuel pump replaced and might as well toss in a fuel filter since its a new pump.
    Sorry to hear your having issues while on vacation =(
    [COLOR="#696969"]
    May 2008
    NW Montana
    DDL,
    Hope you got your situation resolved. There is a new Moomba dealership in Kalispell. Kurt's Polaris is the dealership(no relationship). I honestly don't know what the experience level of the techs are. They are the Nautiques dealer as well.
    Best luck,
    KL
    2008 LS
    Oct 2007
    Panama City Florida
    Hey if they are a Nautique dealer then you can have them install the PCM fuel pump system that according to some local expert is 10 times better than the Indmar system and was designed to eliminate the vapor lock issues they had years ago!
    Ok i got a lecture about that from an Indmar AND PCM certified tech with MANY years experience! I have to admit trying to make allowances for a bad design is not how to sell boats.
    Also!
    I think we need to start putting some data into Excel here, I want to know and compare how many DD's vs. V-drives are having this problem. I am thinking there is something to this also. Who wants to put up the poll? Sled, Moombadaze, Kaneboats? And this is not a us vs. them issue I think there is something here as I don't see many post with the DD's having the problems and as hot as it gets here we have never experienced it.
    I haven't heard of it with a DD yet.
    Sled491 Guest
    Z, I'm with KB on this one, never heard of a DD getting vapour lock. I know just another feather in your cap for the Ultimate crossover boat quest. As you know I'm with you on this one anyway
