Results 1 to 6 of 6
    Aug 2008
    North Dakota
    Unhappy Gravity III Ballast '08 LSV Fuse Panel??????
    My ballast system isn't working. 2 switches are lighting up one isn't. Won't fill or drain. I've read all the posts and it seems like its a blown fuse...but for the life of me I cannot find the 7.5 amp set of fuses. I've tried to rest the breaker and nothing. Does the 08 LSV have fuses for the ballasts and if they do does anybody know where they are???? I'm slowly losing it since it is the nicest weeks of the summer.
    Ottawa, Ontario
    Mine are under the steering wheel. I had the same problem last year.
    2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
    Nov 2003
    Land O Lakes, Florida
    lay on your back, under the steering wheel, look up under the dash. you should see a fuse block that has 6 fuses all label'd for what that fuse does. 3 for the empty pumps and 3 for the fill sprinklers.
    I have a 08 lsv also and thats where mine are located.
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
    Jul 2009
    Spokane, WA
    I just bought a '08 LSV and one of the ballast switches lights doesn't work. The pump works when I flip the switch, but for whatever reason the light doesn't come on. Maybe a loose wire? Or a burnt out bulb? I'll bet they don't make replacement bulbs though...
    Any thoughts on this?? I'd appreciate it!!
    Jan 2006
    Jacksonville, FL
    Default squeeg
    I Just had the same problem. I ordered one from water sports of central florida. Orlandoboats.com. The switch was 10.00 bucks and hey shipped it out to me. Had it in 2 days. Great service.
    Jul 2009
    Spokane, WA
    Thanks 98, I appreciate it. I saw in another post where you had mentioned that's where you got the swith. I thought I might go into the local dealer and see if they've got one, but 10 bucks is pretty cheap! Thanks!!
