Results 1 to 10 of 10
Thread: Drilling fiberglass
07-21-2009, 05:33 PM #1Junior Member
- Jul 2009
- 3
Drilling fiberglass
Just bought some of the etched hide-a-cleats from the dealer for my 2006 Outback. I've read that there is a special technique one needs to do when drilling into the gel coat to prevent hairline cracks. What exactly needs to be done? I'll need to drill one-inch holes, got the hole saw.
07-21-2009, 05:43 PM #2
When drilling 'glass you run the bit in reverse until breaking through the gelcoat, this prevents spider cracks and chipping. However, it has been my experience from drilling many holes in 'glass that a forstner bit does a much better and cleaner job than a hole saw when available in the size needed.
07-21-2009, 06:17 PM #3
07-21-2009, 08:42 PM #4Junior Member
- Jul 2009
- 3
07-21-2009, 09:43 PM #5
I ran it reverse the whole way. I believe others start in reverse and then go forward. The hole saw was enough to go through all the way in reverse.
07-21-2009, 11:02 PM #6
Once you get through the gel there's no benefit to staying in reverse, not that it hurts anything. Just goes faster in forward.
07-22-2009, 11:06 PM #7Junior Member
- Jul 2009
- 3
Thank. Last question; I saw where the cleats were mounted from the factory. Is that the best place or has anyone discovered something better?
07-22-2009, 11:47 PM #8
Mine work well right where they are.
07-23-2009, 12:05 PM #9
Just to be safe I would drill in reverse all the way through. When I put a tower on my old boat I drilled in reverse through gel and then switched to forward. If you are not exactly straight you can still catch an edge and crack the gel. That was the first hole. I then drilled the rest in reverse!!!!
07-23-2009, 01:40 PM #10
Just round out the hole in the gelcoat in reverse before you switch to forward. I just installed 4 pop-up cleats. Man, that was a lot of drilling. Make sure you have the right sockets b/c tightening from underneath can be a bish. I needed a deep well 10mm and didn't have one.
