Results 1 to 10 of 15
Thread: Upholstery spots...can't remove
07-19-2009, 09:31 PM #1Junior Member
- Jan 2007
- Renton, Washington
- 15
After a great weekend of boating and camping, I was cleaning up the boat and discovered 7-10 spots on our seats. It appears it came from a tree at the campground, like pitch or something like that(yellowish-green color). It comes off the fiberglass okay but I can't find anything that will work on removing it from the uphosterly. Has anyone had this problem and/or any suggestions?
07-20-2009, 09:13 AM #2Senior Member
- Jan 2008
- Pensacola, FL
- 1,585
Try vinegar and water first. If that doesn't work, try ammonia and water. Make sure that you are in open air when using ammonia.
I am assuming that you have try standard boat cleaning products.1997 MasterCraft 205
2008 Moomba Outback
1999 MasterCraft Sportstar OB
1992 MasterCraft 205
1999 Malibu Response LX
1987 Marlin Magnum Skier
07-20-2009, 10:45 AM #3
One product will do that and so much more...Mr. Clean Magic Erasers. I am sold on them, they clean the upholstery, the fiberglass, and so much stuff around the house its crazy. Go pick up a box at Walmart and let us know how it worked...I'd bet serious cash that they will clean up your spots with just a little elbow grease. (just make sure to get the eraser nice and wet first)
07-20-2009, 11:24 AM #4
Magic erasers are abrasives. They will remove vinyl topcoats, and even the texture and color of vinyl with continued use. Yes, they will clean everything because you're essentially sanding away the dirt.
07-20-2009, 01:27 PM #5Member
- May 2009
- sun city, az
- 33
Mr Clean's Magic Erasers seem to get rid of everything!!!
07-20-2009, 02:10 PM #6
07-20-2009, 04:50 PM #7Senior Member
- Jan 2008
- Pensacola, FL
- 1,585
07-20-2009, 05:28 PM #8
I'd first try to use heat to soften the sap and try to pick it off the surface. Vinyl cleaner with a stiff brush might get it too. Otherwise you'll need to used a degreaser of some kind... Goo Gone would do it.
07-20-2009, 09:11 PM #9Senior Member
- Jun 2007
- Calgary Alta Canada
- 926
Goo gone was suggested to me as was fantastic without Bleach.
07-20-2009, 10:48 PM #10Junior Member
- Jul 2009
- 1
I used the magic eraser on the cousions after a trip to powell and they were a god send! I put extra's in baggies on the boat for emergency use.
