Results 1 to 3 of 3
    Jul 2002
    London Ontario Canada
    Default bertha ballast leak
    I've just discovered a leak from my right side ballast drain pump. i can see water shooting into the boat when i turn on the drain pump. Any hints on how to fix. Do i get at it by taking the storage compartment apart? Its a 99 Outback LS.
    thanks, doug
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Aug 2002
    Maryville, Tn.
    Default Ballast leak
    Doug, I would make an appt. with my local dealer to verify that leak. It is a very tedious task to try and repair or replace any components in that sysyem without knowing removal or install instructions. The servicing dealer should be able to assist you in your situation.
    Jul 2002
    Default PROBLEM
    fOR ANYONE WHO WANTS TO KNOW . THE RULE DISCHARGE PUMP HOUSING SEPARATED. IT TOOK ABOUT 1.5 HRS TO GET THE TANKS OUT OF THE BACK OF THE BOAT. ENVIRINMENTALLY FRIENDLY ANTIFREEZE MUST BE PUMPED INTO THE DISCHARGED PORTS TO ENSURE FREEZING OF THE PUMP HOUSING DOESN'T OCCUR OVER THE WINTER
    NEVER ENOUGH TIME TO SKI
    P.S. BRIAN REDMOND AT SKIERS CHOICE WAS VERY HELPFUL IN HELPING ME IN THIS MATTER
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
  1. 2004 Mobius LSV - Single Bertha Ballast Issue
    By Shoemaker Mobius in forum General Chat
    Last Post: 03-14-2007, 02:43 PM
  2. Gas leak
    By toelke4286 in forum Service & Repair
    Last Post: 11-08-2005, 06:29 PM
  3. Bertha Ballast: 3 Bag System
    By madmax in forum Service & Repair
    Last Post: 08-24-2003, 07:22 PM
  4. bertha ballast
    By DOCDRS in forum Boat Owners
    Last Post: 10-09-2002, 11:31 PM
  5. Leak
    By brucevanderbilt in forum Boat Owners
    Last Post: 07-23-2002, 10:41 AM
