Results 1 to 10 of 17
Thread: New Z5 Cargo rack - trailering
07-17-2009, 12:37 PM #1
Do you guys trailer with your Z5 installed? According to Z5 FAQ's, they say the 2009 Z5s can be trailered as long as you tie down the front straps. How many of you trailer with the Z5 in place? My usual commut is about 30min on the highway.
Otherwise, where would you put it - doesnt fit well in the back of the truck.2009 Moomba Mobius LSV Liquid Force. Indmar 340HP CAT
07-17-2009, 12:48 PM #2
No problem, I have gone 2.5 hours one way without the straps. My Z5 barely moves. Its nice and strong. My max speed is about 75 mph and I average around 65 mph. If your only going 30 min away I guarantee you will not ave any issues.
07-17-2009, 10:47 PM #3Member
- Jun 2009
- 83
I do not know if the 08 and 08 z5 cargo tops are different, since mine does not have any straps, but I have left it on and towed up to 70 mph and a hour long drive with no problems, other then bugs.
________
Medical Marijuana CardLast edited by jetpilot2002; 03-06-2011 at 02:43 AM.
07-18-2009, 12:00 AM #4
Just returned from my trip today. 9 hr drive and no problems with the Z5 Cargo Rack. I just have to say, IT IS A MUST HAVE. Best mod I ever done to the boat.
07-18-2009, 10:25 AM #5Member
- Feb 2009
- Central, WA
- 44
Z5
Z5 told me to add two front tie down straps when towing which they sent to me and a couple of hold down brackets that I screwed into my tower to attach them to. First trip out and the straps came loose and marred up the tower. So, now I don't use them and haven't had any issues, just was trying to follow thier rec. I think the straps are a good idea for long trips, but need to be ratcheting to get them snug. They sent ones that just have an adjustable tarp style bracket that you get snug and hook the straps. However, the bracket won't stay tight while trailering. Also, they suggested taking the cargo webbing off the top while trailering as the two pieces of fabric will wear on each other. I took mine off as I don't really use that feature and did notice some minor abrasions. My boat had 20 hrs on it at the time.
2008 Supra 22V
07-18-2009, 12:09 PM #6Senior Member
- Oct 2007
- Panama City Florida
- 1,798
Ok I probably have the most miles and hours towing a Z5 and just a week ago while 300 miles from home we gave the top a Real Good Inspection. Let me add the mileage and hours up for these trips up for the past year.....ok this is NOT for my local trips to the gas station or the boat ramps but 4 actual long distance trips. I towed it 2100 miles in one year and for about 50 to 60 hours time towing while doing it at 65mph.
First thing we noticed was that spider type hold down (for tubes and other big stuff) was getting worn bad and was also wearing against the canvas top even though it was never used. Took it off and stowed it in the boat incase we need it.
The canvas top, after this inspection we decided that the canvas had to come off for the trip home! And in the future it will for any trip over 30 minutes. It is starting to look tired from all of flapping around it does while towing at 65mph. I can only image the cost of just the Canvas from a dealer!! I also was thinking that my fuel mileage might increase a little too without that sail back there!
The frame work on the top is awesome looking and there was no wear or any other issue here. I believe they are requesting you to install the straps as a back up incase you forget to put in your safety pins and the top were to rotate down accidently, wow then you would have huge sail bouncing up and down and all the associated forces of wind at 65mph acting on that! Yeah there would probably be some damage then!
So in the future we will pull the canvas off for any trip over 30 minutes, especially if the speed will exceed 50mph! And I think I did notice a small increase in my mileage on the trip home and I actually drove faster (70mph) because I did NOT have to worry about the canvas fluttering! Yep it was worth taking it off!!!
Tazz is correct this is a GREAT FEATURE well worth the money we spent!!!!Last edited by zegm; 07-18-2009 at 12:12 PM.
07-18-2009, 02:53 PM #7
After getting into Zegm's boat this last weekend and looking at the Z5 a little more, I really wished I had know how this worked when I picked up my boat as it would be sportin the Z5 now. That is a really tight bimmini and storage top.
Hey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
07-18-2009, 06:12 PM #8
ON my Z5 i use the straps when i take it on the road. The real porpose of those straps to keep the front of the cover tilted Down slightly. It will ack more like a rear spoiler on your car then.
Depending if you have the Z5 tilted down in the front more or tilted up in the front the straps till ensure when the wind is hitting it, it doesn't put extra stress on the hinges, causing it to tilt back in the < Open > position.
Open position is considered the loading and unloading gear position.
The straps are strictly a safety device and for the most part have no real use. You don't want to tighten those little front straps so tight the cover is being forced forward or you cause extra wear and tear to the plastic bushings in the ball sockets for tilting.
As for the canvas material. The spider webbing is only supposed to be on the Z5 if you have gear stowed there. No gear then take off the spider web because it wont stay tight with no pressure under it.
Main canvas material on mine is super tight and doesn't flex or flap at all so no wear as of yet. I have been told if you take it off its a real pain to get it on tight again with all the little plastic rollers it uses to keep the rope in the canvas tight.
Cleaning it i was told to use mild detergent a soft brush and water. Just scrub it by hand in the grass or hanging up and let rinse it really well and air dry on the frame. Dont wash it off the frame to minimize any shrinkage.
These are my tips from the dealer and my own experience so far. Longest trip is only 125 miles 70mph.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
07-18-2009, 10:31 PM #9Senior Member
- Oct 2007
- 1,798
mmandly,
It took us a few minutes to figure out how to get the top off. AND we haven't put it back on yet as the boat is now sitting in the driveway. Tomorrow we are putting the boat back on the lift so I will let you know how difficult it is to get it put back on correctly. As far as the angle of the top to horizontal, it is determined by the ball height of the hitch on the tow vehicle. Luckily the front of our trailer is a little lower than the rear while we tow. But the peace of mind I had while towing the boat for 6 hours and not having to worry about it was worth taking it off!
07-19-2009, 02:53 AM #10
Yea i hear ya hear man. Let me know how that goes putting it back on. I dont recal if it was AWS or another owner i know in the area who took one off and fought with it to get it back on lol.
Id like to know because in Sept we are going to Utah for vacation and taking the boat. Only about 700 miles but still a good bit of distance.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
