    Default Low oil pressure?
    At idle, my oil pressure is fine (around 40). In reverse, my oil pressure is fine. Once I start going forward, the pressure goes to practically zero and stays there until I get around 22 or so, then it is fine again. Plenty of oil on the dipstick, engine does not seem to be running hot.
    Any ideas?
    Jeff
    The dealer changed the oil at the end of the last season.... we've had the boat out three times since then. I wonder why an oil change would fix that?
    Default Solution
    For posterity's sake, we found the answer to the issue with the oil pressure. My auto mechanic hooked up another pressure gauge and discovered that the actual pressure was fine. He also cleared the gauge as being the trouble. Evidently, the sending unit is bad.
    Oct 2008
    Central, Arkansas
    Thanks for the udpate. Love to see closure to issues.
    2014 Mojo Surf
    2013 Mojo Sold
    2010 LSV Sold
    2002 OB LSV Sold
    Jun 2009
    Minneapolis, MN
    Thanks for the update. I'm having this same issue and I suspect its the OPSU as well.
    Sold my Moomba. Currently boat whoring.
    Set Ups - 09 CWB Transcend Platinum w/ 09 Ronix Cells (his) and 08 Liquid Force Angel w/ 08 Alloys (hers)
