Results 1 to 7 of 7
Thread: Drain plug for ski locker
07-13-2009, 03:03 PM #1
I'm considering installing a drain plug to the drain of my ski locker along with a seperate bilge for that area. I'm hoping that by doing so, that area will stay a bit dryer or at least cleaner. I need to know what size that is, where to find such an item, and has anyone else done this to their boat. My boat is a 2004 LSV.
www.louisianawakeboarding.com
2004 LSV
Perfect Pass, Integrated ballast (front, rear, middle), Wake Plate, Tower mounted bimini, Swivel board racks, Surf board rack, Tower mounted mirror, Keel guard, 4 tower speakers, 12" sub, 2 amps, transom remote, Bow filler cushion, and the list continues to grow.
07-14-2009, 01:15 PM #2
1 1/4, get a test plug from the local hardware store with a wing nut.
http://www.acehardwaresuperstore.com...94.html?ref=42A Day at the Lake...Priceless
07-14-2009, 02:18 PM #3www.louisianawakeboarding.com
2004 LSV
07-14-2009, 03:17 PM #4Banned
- Oct 2005
- Durham, NC
- 649
I am not quite sure what you are trying to do. Are you wanting to install another thru-hull drain plug? If so, I am not sure the one from ACE will do the trick. I have a DD so my bilge drain is under the engine in my boat. I wanted to get a spare plug "just in case" for it. I picked up a factory style Perko one from the local Mastercraft dealer. As a side note, he wouldn't sell me just the T handle plug, I had to buy both pieces. It wasn't cheap either, I think it was around $40.
07-14-2009, 04:57 PM #5
I think he's just talking about the hole that leads from the ski locker back to the bilge area on a v-drive. No thru-hull in this case. The ski locker gets slimy for some reason, guessing it's from bilge backwash.
I'll be interested to see if this plug works out. I don't think I'd mess with another pump, instead just pull the plug occasionaly and let any water drain back to the stock bilge.
07-14-2009, 06:33 PM #6Senior Member
- Jun 2006
- 194
I have a 2004 LS, I use a cork from a wine bottle.
07-15-2009, 12:51 PM #7www.louisianawakeboarding.com
2004 LSV
