Thread: 05 Mobuis LSV
    Jul 2009
    Default 05 Mobuis LSV
    I have a 05 Mobuis LSV. I just started Wakesurfing and already want a bigger wake Does anyone know if I can put a 750Lbs. bag in me rear compartment by the motor. I have the ones that come with boat I believe they are 250lbs. Who makes the factory sacs anyway?
    Mar 2008
    DFW Texas
    Yes, the 750lb will fit, it is actually larger than the compartment but it does work fine. I have the 08 Outback V (same hull) and the 750lb is great. The sacs are made by Fly High 750lb part # is W707.
    -McMoomba
    2008 Outback V
    Nov 2008
    I have the same boat and put a 750# in the surf side locker. I would say I can probably only fill it to about 650#, but it's still great. Only thing to look out for is make sure you don't have any random screws sticking through into that compartment, or your 750# bag will find it. We had one that I had to put thread protectors on so it doesn't pop the bag.
    You will also most likely need to extend your fill hose because the fill hole on the 750# sits much higher than it does on the 250# stock bag. I just added an additional 12 inches of tubing to reach it.
    Sled491 Guest
    Don't forget to add some extra weight up front to lenghten the pocket as well.
    Feb 2008
    Arvada , Colorado
    Default 05 lsv wakesurfing
    Hey there, I have 350lbs bags each side in the rear compartments . I fill one on the side I surf on and have someone sit on the sun deck on that side . Front bag is filled and someone is sitting in the seat on the left side across from the driver , wake plate at 1/4 from down all the way and right at 10 mph or a little less. I usually wait till the wake clears up then go into it. I tried alot of different settings and such and this works the best for me.
    Jim.
    05 Mobius lsv , ballast system , stereo, etc..
