Results 1 to 7 of 7
Thread: Vibration in reverse
03-30-2004, 11:36 AM #1Senior Member
- Mar 2004
- Wylie, Tx.
- 212
I noticed the other day, that I have vibration while in reverse. I don't know what causes this. The only thing that I could figure is, shaft out of alignment or bent. Any thoughts would be appreciated.
MedicMedic151
06 Mobius XLV
03-31-2004, 09:04 AM #2Member
- Aug 2003
- Canada
- 61
Replying to Topic 'Vibration in reverse'
Is there any vibration in forward? Is it a carb engine?
boomerang
03-31-2004, 12:57 PM #3Senior Member
- Mar 2004
- Wylie, Tx.
- 212
No there isn't any vibration while going forward and it is a Carb engine.
MEDICMedic151
06 Mobius XLV
03-31-2004, 04:44 PM #4Member
- Aug 2003
- Canada
- 61
In reverse there seems to be more drag on the transmission. This can make the motor (worse with the carb version) chug and "shudder" at low speed, particularly in reverse. I would still check the balance of your prop and allignment of the drive just to be sure.
My carb runs rich at idle. This makes for a "lumpy" tickover even in neutral. I am going to work on this in the spring (our lake is still frozen). I will keep you posted.boomerang
04-02-2004, 11:12 AM #5Senior Member
- Mar 2004
- Wylie, Tx.
- 212
Thanks, I will check it out.
MedicMedic151
06 Mobius XLV
04-02-2004, 12:26 PM #6Junior Member
- May 2003
- ohio
- 28
My boat initially had a vibration when strating to go into reverse. What i found was that the dealership did not tighten down the nut on the prop shaft. It was out about 3/8". When i tightened it the vibration wend away. -not sure if yours is or not but maybe something to look at.
Love the water!!!
04-04-2004, 10:03 AM #7
My boat didn't vibrate but I did find the prop nut loose(about 1 turn)after about 10 hours.
jy
Vibration
By Longshore in forum Boat OwnersReplies: 2Last Post: 06-14-2007, 08:00 PM -
Hello Vibration!
By jpengelbrecht in forum Service & RepairReplies: 3Last Post: 08-30-2005, 02:44 PM -
No reverse after warm-up; slipping in forward
By Ian Brantford in forum Service & RepairReplies: 0Last Post: 06-20-2005, 07:35 PM -
Vibration
By Allterr in forum Service & RepairReplies: 10Last Post: 04-16-2004, 07:49 PM -
Vibration
By MartyC in forum General ChatReplies: 6Last Post: 05-10-2003, 03:18 AM
