Results 1 to 6 of 6
Thread: streering cable
06-29-2009, 12:11 AM #1
streering cable
have any one had to replace there steering cable? i just got another lsv and the steering is very tight ,it is a 05 with 120 hours this seems to be very low hour for this to happen is it not?
06-29-2009, 03:32 PM #2www.louisianawakeboarding.com
2004 LSV
Perfect Pass, Integrated ballast (front, rear, middle), Wake Plate, Tower mounted bimini, Swivel board racks, Surf board rack, Tower mounted mirror, Keel guard, 4 tower speakers, 12" sub, 2 amps, transom remote, Bow filler cushion, and the list continues to grow.
06-30-2009, 11:11 PM #3Junior Member
- Jun 2009
- Minnesota
- 9
I have 140 hours and have had mine replaced twice. They tell me I should pull the plug every weekend to make sure the boat drys out. Have not been very happy about this issue
07-03-2009, 10:07 AM #4Member
- Apr 2007
- 38
I have also had to replace mine twice. What I have learned is that it is very difficult to get all of the water out of the bilge, and the lowest point of the boat seems to be where the cable mounts to the rudder. So, the end of the cable sits in the water, and the water migrates up the cable and it eventually corrodes. These days, I try to take my wet vac to the bilge after I put it back in the garage. On days when the ramp is not crowded I also try to drain it as much as possible while on the steep incline before I take it home.
07-03-2009, 10:15 AM #5
You guys are scaring me, i think just last week wake surfing the steering seemed tighter then normal, i never pull the plug on my boat as every time i do nothing comes out. I see some water sitting in the bottom of the bilge area but not enough to make the pump kick in.
I guess i better start pulling this plug on the way up the ramp, the lake we go to the wipe down area is on a steep Decline, so nose down ass up, not very practical for draining water or ballast.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
07-03-2009, 01:41 PM #6Senior Member
- Mar 2004
- Martinsville,Indiana
- 213
o4 LSV had to change mine after 4 yrs.Pretty easy job.Cable waws about 150 from Moomba.
