Results 1 to 1 of 1
Thread: Perfect Pass and Throttle Cable
08-17-2009, 01:16 PM #1
So I'm having problems with my perfect pass and the throttle cable. When I set the perfect pass for a specific speed and I take off, the perfect pass beeps when it hits the desired speed, but can not hold it at that speed. The boat looses speed and just stops as if I brought it back to neutral. The dial on the throttle cable is completely turned and the cable is pulled out and loose. I tightened it back up, and it keeps having the same problem...but only when I use the perfect pass...the throttle cable works fine manually. Wondering if there is something mechanically I can check, or if this is in the computer system of perfect pass? Thanks for any help or comments.
Jeremy2006 Mobius XLV
