Results 1 to 6 of 6
Thread: Fuel Gauge Bounce
03-25-2004, 05:43 PM #1Junior Member
- May 2003
- ohio
- 28
Fuel Gauge Bounce
I have an 03' Outback and last year there was much talk of all the problems with the fuel gauges and/or sending units. What has been determined as the fix?
Love the water!!!
03-25-2004, 07:48 PM #2Member
- Dec 2003
- Seattle,Wash.
- 49
Replying to Topic 'Fuel Gauge Bounce'
Have a 2004 Outback one month old and at the dealer right now for 10 hour service.
I would say the problem has not been resolved. Once my guage comes off of full, approximately 45 minutes to 1 hour of running , the guage is all over the place. I refuel after each time out and am figuring how many gallons a hour ive used and going from that.
Love the boat and this is the only issue Ive had.
Larry
03-26-2004, 04:57 PM #3Junior Member
- May 2003
- ohio
- 28
they did blow off the issue and sorry to see they did not get it corrected on the '04 models. Wonder if they will atleast respond though.
Love the water!!!
03-27-2004, 09:40 AM #4Senior Member
- Oct 2003
- Northern Kentucky
- 110
Guys, I know we want everything to work, but I am on my fourth boat and have never had an accurate fuel gauge. My last boat was a 1999 Malibu Response, and it did the same thing. Are they crazy all the time, or just when running? Not had this Moomba out but once, and really did not pay any attention to it, but on my Malibu it was accurate when sitting still.
03-27-2004, 10:03 AM #5
I agree. I'm also on my 4th boat and none of mine have been accurate. Some have bounced around more than others have and some seemed a little more accurate than others did. I've had to replace a sending unit in the tank before. You have to adjust the sending unit to the depth of your tank to get it as accurate as possible but that still doesn't keep the needle on the gauge from bouncing around. Adjusting the sending unit correctly is the only thing the boat manufacture can doe to effect the accuracy of you fuel gauge. We’ll just have to wait for the gauge manufactures to make better gauges. As far as I know, all boat owners have the same problems with fuel gauges to some extent.
96 Moomba Boomerang
http://webpages.charter.net/oscar91/...ges/TheRig.htm
03-27-2004, 07:45 PM #6Senior Member
- Apr 2003
- Powhatan, VA
- 316
One fix is a set of baffles in the gas tank, including a set around the sensor if its a mechanical one. Infrared sensors are available for chemical tanks, I'll bet they are also available for boats. Issue is probably money.
Fuel gauge bounce
By Troy in forum Service & RepairReplies: 28Last Post: 05-20-2010, 11:19 PM -
Fuel flow gauge?
By TL7 in forum General ChatReplies: 1Last Post: 03-23-2008, 08:50 PM -
Fuel Gauge
By Gharvin in forum Service & RepairReplies: 12Last Post: 09-21-2006, 03:52 AM -
Fuel Gauge Accuracy?
By Swairlines in forum Service & RepairReplies: 0Last Post: 02-13-2006, 10:27 PM -
MPH, Fuel Gauge
By wakesurfer1 in forum Sales & InformationReplies: 2Last Post: 05-06-2005, 04:56 PM
