Results 1 to 7 of 7
Thread: Trailer winch slipping
06-17-2009, 11:00 PM #1
The winch on my trailer is pretty weak... if I don't power the boat all the way up and try to use the winch to cinch it tight it just slips (strap spins inside). It's basically like not having a winch at all. Any ideas what might be the issue?
06-17-2009, 11:32 PM #2
sometimes the handle can get stripped. it happened on my buddies four winns. the square slot for the handle on the bolt got more round with use and it would just slip. Maybe a new handle, TSC or someplace may carry them cheap for a replacement if the handle is stripped.
06-17-2009, 11:42 PM #3
I should have given a little more detail. The strap winds tighter, but instead of pulling the boat in, the inside of the strap is winding tighter and bunching up.
06-18-2009, 10:38 AM #4
That can also happen with winding up the whole strap with no tension on it. Best thing to do is pull the whole strap out, make sure it is attached properly, then put some tension on it and slowly wind it back up. If it's nice and tight then you will be able to pull the boat otherwise it will just keep tryin to spin and tighten itself. May have to wet your bunks a little too before you trailer.
06-18-2009, 05:08 PM #5
06-18-2009, 07:27 PM #6
06-18-2009, 07:32 PM #7
