Page 18 of 20 FirstFirst ... 81617181920 LastLast
Results 171 to 180 of 198
Thread: my 08 LSV mods
  1. #171
    Aug 2011
    Default Re: my 08 LSV mods
    Sounds like someone's engine is running way rich..
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV
  2. #172
    Aug 2011
    Newnan, GA
    Well crap, it's done that since it was new. I will get Atlanta Marine to take a look. Thanks
    2015 Supra SE 550
  3. #173
    Des Moines, IA
    I've been able to get some time with the FAE and it's definitely a huge improvement. Zero changes to the wake and I'm happy about the reduced fumes, and just wish I had a way to measure the improvement.
    The new y-pipe design is awesome and looks OEM, which it probably should be as an option. Overall it's just a high quality upgrade. I'm glad to see so many people get in the group buy and am guessing there will be a lot of happy customers on here.
    I notice a major decrease in sound at start-up and idle, to the point where I can't always tell if it's running or not. Surf speeds are much quieter too and hearing the water on the sides of the hull is just as cool as people have described. Wakeboard speeds are definitely quieter than before but it's not like you're in an electric boat, and when you hammer the throttle there is still plenty of engine roar like you would expect.
    It will make winterizing super easy this year too. I'll just put a pail full of antifreeze under the FAE and run a hose from the bucket to the vdrive fake-a-lake and let it run.
  4. #174
    Jun 2013
    Default my 08 LSV mods
    Good thought, another great benefit that I didn't even realize!!!
    Mike
    2013 Outback V
    - FAE
    - DIY suckgate
  5. #175
    Aug 2013
    DFW
    My wife said today when we were on the way to the dealer "I know you'll say I told you so, but I want our next boat to have a FAE". Then she started talking about saving money now for all of the adds we'll want to make right from the start (FAE, Exile, Ballast, and Samson mirror)... And we aren't upgrading until the 2017 model year
    Matt
    2016 Mojo
    2012 LSV (sold)
  6. #176
    Nov 2013
    Kansas City, MO
    Would the raw water pump have enough draw to pull from a bucket?
    2007 LSV
  7. #177
    Des Moines, IA
    Quote Originally Posted by Beejwest View Post
    Yes, that is how I do it every year now, just without the FAE to collect the antifreeze. A hose directly connected forces water through the system (at least with my water pressure and connected to the vdrive) and so the boat doesn't ever get up to temp. Using a bucket with a hose to fill you'll see the system not pull any water for awhile, then pull water in like crazy.
  8. #178
    Des Moines, IA
    Never have used the head unit so I removed it and put this slightly tacky storage container in its place.
  9. #179
    May 2013
    Vancouver WA
    The Clarion EQ has been excellent, but I really wanted a mic. WetSounds 420sq:
    Thanks! The EQ install took some time because I had to buy a blank switch plate (just finding the manufacturer and convincing them to sell me a blank version took some time.) Then recutting all the switch holes and spot for EQ with a dremel.
    How much was the blank switch plate? Do you think they'd sell another?
    Heck, if you could convince them to copy your template, they could EASILY sell them pre-cut for either the 420 or ZLD and make some money.
  10. #180
    Des Moines, IA
    I had to buy 5 plates from them to make it worth their while. Since it's a large manufacturing shop that doesn't sell direct to consumers it took some convincing for them to adjust their line to not cut the holes and then only do a run of 5. I had to create a purchase order and jump through a few other hoops as well. I think in total it was around $300 but not sure. I would recommend just using fiberglass to cover all the existing holes and then wrap both this panel and the ignition panel in the same vinyl to either match stock or go carbon fiber.
