Thread: electrical issue with 08 xlv
06-09-2009, 10:11 PM #1Junior Member
- Jun 2009
- 4
my horn, bildge and perfect pass want work and I cant get any power to them do you have any suggestions
06-09-2009, 10:30 PM #2
check the circuit breakers next to each switch. They are tge little black buttons under the switches. If that does not work, check the fuses.
06-09-2009, 10:56 PM #3Junior Member
- Jun 2009
- 4
yep checked both of em
06-10-2009, 12:16 AM #4Senior Member
- Jun 2008
- Eugene OR
- 1,786
Is everything else working? You might want to check to see if a wire came loose. Has somthing happened since the last time they did work?
