Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: hole in transom
  1. #11
    Apr 2008
    California
    You also use a strain relief fitting if you can find one small enough for your wire size.
  2. #12
    Dallas, TX
    ABC,
    For under swimdeck lights we palce a mini stainless steel clamshell just above the swimdeck. We seal the penetration and fill the clamshell with marine silicon. We also have a silicon sealed quick-disconnect so you can still remove the swimdeck.
    For true transom-mounted underwater lights, like the ABYSS for example, where the penetration is underwater, we use a poly sealer. A poly underwater sealer stays forever compliant so it never hardens or shrinks. I don't like the 3M 5200, which many use, because if you ever have to remove and service anything, the gelcoat might come off with the part.
    Earmark Marine
  3. #13
    Apr 2008
    California
    David, you gotta pic of that mini clamshell?
  4. #14
    Quote Originally Posted by tazz3069 View Post
    mmandley--
    you can find those on Ebay. i did. I did not like the black plastic ones that came with the boat. So I did a search on ebay and found them. Cant really remember how much I paid for them but they really look alot nicer than the black ones.
    I found them on Ebay also, do you recall what size threw bolts they are? As hard as most of then are to get to i don't want to pull one out just to measure it if you recall the size.
  5. #15
    well, we hijacked this thread - sorry
    Mike,
    Newty used the 3/4" ones. This is from his reply post on Sled's Mods:L
    Looks great! Those thu-hulls are nice huh? I Love the wrap but I'm suprised they don't wrap the black to match. Kind of a weird transition.
    Jester they have a threaded nut on the back and a barb fitting for the hose. Super easy to do... if you flexible enought to get under the dash.
    I have 5 of them on my boat now.
    Heres the link to the guy I got them through. Check out the pic and you will see what I'm talking about.
    http://cgi.ebay.com/ebaymotors/Set-3...4574QQtcZphoto
    While that item # shows being ended, it looks like you can still get them from this ebay seller: http://cgi.ebay.com/ebaymotors/Set-3...ssoriesQ5fGear
  6. #16
    Thanks Wolf i was looking and both places i found them had been closed and all i was finding were the adds for 20 each, not 20 for 3.
    Anyone got extras, i need a 4th lol.
