Results 1 to 8 of 8
Thread: Ballast problem
06-07-2009, 03:23 PM #1Junior Member
- Jun 2009
- Vacaville, CA
- 5
Ballast problem
My port rear ballast won't fill or drain. Thought it was valve at first. I changed it with no effect. When I switch the plugs at the valves(under tran. cover) it fills up but still no drain. The lights come on switch at the panel. I would love any advice that could help. Of course this is the side of the boat I wakesurf on! Thanks for any help....
06-07-2009, 03:27 PM #2Junior Member
- Jun 2009
- Vacaville, CA
- 5
By the way it's a '07 LSV
06-07-2009, 05:35 PM #3
Look up under you dashboard, lay on your back and look straight up and you'll see a small fuse block. These are the fuses for your ballast system. Start there befoer moving on.
06-07-2009, 07:03 PM #4Senior Member
- May 2008
- Seattle, WA
- 104
Yep, yep, yep.... listen to Razz. I thought my whole system was screwed up until I got under the dash and found all three 7.5 amp fuses blown. Replaced them all and the complete system works again. It will say something like left (rear), right and front as labels on that fuse block. There are 6 total fuses on that block.
06-07-2009, 10:23 PM #5Junior Member
- Jun 2009
- Vacaville, CA
- 5
You guys are awesome.... I appreciate the fast response. I will check that out tomorrow
06-08-2009, 04:27 PM #6Junior Member
- Jun 2009
- Vacaville, CA
- 5
Blown fuse....thanks for the help!!!!
06-08-2009, 04:47 PM #7Senior Member
- May 2008
- Seattle, WA
- 104
06-09-2009, 01:18 AM #8Junior Member
- Jun 2009
- Vacaville, CA
- 5
luckily the valves are only $13. So that's all I wasted and now I've got backup. Saved me a bundle and now I feel more confident working on my own boat. Thanks for the help!!!!
