Results 11 to 20 of 28
06-04-2009, 08:18 PM #11
Full service at winterization to include filters and fluids ~ $185
06-04-2009, 08:21 PM #12Member
- May 2008
- Jacksonville FL
- 42
06-04-2009, 08:34 PM #13
no. It did not include the prop. If you are refering to the impellor for the water pump, I did that myself. $32.00
06-04-2009, 08:36 PM #14
$62 here for impeller installed. will do myself next time..
06-04-2009, 08:38 PM #15
There telling me i need to replace the impeller at the 100Hr service.
I thought as long as you replaced it each season your good to go. Id like to think if your running the boat that often it will last the season.
Its the sitting for 6+ months and it drying out that makes it fail no?Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
06-04-2009, 09:15 PM #16
Not neccessarily Mike, my brother-in-law ran his for 4 years! Some people will pull it at the end of season and bag it in vaseline until spring. I've never done that. Some people replace it every year. I've never done that. I'm on the same one from last year and it works fine, doesn't mean i don't have a spare though. Heat & debris is mostly what kills them.
That's the reason i anchor out from shore & start out there so i don't suck sand and such into the impellar and never run the boat in close or into lake weed. Now an old one can crack over time but seriously there's no reason to replace every year unless you do a lot of hours.2007 Mobius LSV
06-04-2009, 09:16 PM #17
Btw my dealer also concurred with my assesment after i explained it to him.
06-04-2009, 09:55 PM #18
If you change the impeller every year for $35 yourself, tell the dealer to stuff it. Somebody else said the dealer "checks the plugs". What do they check? Change those every year your self as well. A set for my boat was like $25. Do the easy stuff yourself and save the money for when something breaks.
06-04-2009, 10:41 PM #19Senior Member
- Jun 2008
- Eugene OR
- 1,786
The Plugs would be easy to do all you need to know is the gap and i bet someone on the form knows that. How hard is the impeller to replace? Sounds like it is easy? Changing the oil should be easy?
You know i think we should put together a how too book on the services. I think the hardest part is finding where everything is located. Also put a ranking on how hard it is too do for an average person.2008 Outback V - Sold but never forgotten.
06-04-2009, 10:59 PM #20Member
- May 2008
- Jacksonville FL
- 42
